Old 09-15-2018, 05:51 PM   #1
Need Advice - Squeaky Cab Over
We have a 2018 Dynamax Isata 3. By and large things have gone well for the first few thousand miles. There were a few punch list items of course and those are being worked through the selling dealer. One thing that is bothering me is the squeaking in the cab over by the shelves and TV and the interface between the Mercedes Benz cab and the house. I’ll attach a few pictures about where it appears to be coming from once I figure out how. My questions are: (1) Has anyone had a similar problem? (2) Are there known typical solutions? (3) Did anyone do it themselves? (4) Try the dealer? (5) Take all the way to Dynamax (if possible)? Thanks for any information in advance. Rob. :-)
ID:	186598   Click image for larger version
ID:	186599   Click image for larger version
mncp8r is offline   Reply With Quote
Old 09-15-2018, 09:04 PM   #2
caswelld's Avatar
We also had a squeak in the area of the TV. We found that placing a paper towel around the pin that locks the TV bracket, then carefully inserting the pin in the hole stopped the squeak. It was the pin that was causing all the noise.
Not sure of other sources of cab squeaks.
Dave & Julie
2018 Isata-3 24FW - Invisibrake/Roadmaster Falcon All-Terrain Tow Bar - 2017 Fiat 500 Abarth towed
2015 Tiffin Allegro 36LA-Wrangler Sahara Unlimited towed
caswelld is offline   Reply With Quote
Old 09-17-2018, 10:28 AM   #3
GM
bclemens's Avatar
Therin lines the catch 22 of the articulating bracket. We had fixed, but most people want articulating, but with articulating there are more joints...joints that make noise.
I have seen two solutions.
1. as listed above, keep the pin from sliding up and down.
2. get a neck pillow and stuff it behind the TV to keep the TV and whole assembly from moving. (I think someone on here cut a big chunk of foam)
make that 3....turn the radio up
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 09-17-2018, 10:42 AM   #4
I Don't Think That's It
Brian - Thanks for your reply. I really don't hear it from the TV area though. My TV is actually tight enough where I have to work pretty hard to get it locked in. The noise seems to be directly over the driver's and passenger's heads. Depending on how old you are you might understand a comparison to one of those old all styrofoam coolers making squeaky noises when you took the cover off and on. If it were me, I'd just add a couple more speakers near the windshield and turn the stereo up but my travel partner isn't as deaf as I am and doens't appreciate being blown out of her seat. Any other ideas? How is the chassis connected to the house underneath everything? Best regards, Rob
(ps - I have to say that having a GM who cares enough to be on line is really a game changer for deciding to choose or stay with a brand. We'll be moving up - probably to a Super C in the next year or so and will be looking at Dynamax first for just this reason.)
Old 09-17-2018, 10:47 AM   #5
GM
bclemens's Avatar
You have to be careful about sound transmission. A while back, on the 5 series there was a squeak that many thought was the cab over...swore by it and maybe one was, but many found it ended up being the back up camera that was clipped over the rear view mirror. It was squeaking and the sound was bouncing off the windshield.
As for the 3 series...there is a big U-shape metal bracket that attaches to the roof of the cab and then we tie the front end into that. We use fiberglass insulation in that front end, so it wouldn't be that. I would try with the cabinet doors open first...see if maybe the catches are squeaking. Those are plastic parts.
Old 09-17-2018, 04:49 PM   #6
hook47's Avatar
My DX3 has a similar Styrofoam squeak overhead in the cab. Pushed on wood work and doors and didn't stop squeak. Will work on it more after I get it back from having the rear cap replaced.
BC, I wonder how many of the younger generation knows about "catch 22"? I've used that phrase and have been met with blank stares. But then, a lot of what I say gets the same reaction!
2018 DX3 37RB - 2017 Jeep GC Summit towed
hook47 is online now   Reply With Quote
Old 09-18-2018, 05:50 AM   #7
I’ve got that same squeak and have not been able to find the source...please post up if you find something. Do you have the cab-over bunk?
2018 DX3 37BH
mookieblaylock is online now   Reply With Quote
Old 09-18-2018, 07:44 AM   #8
Happy to do so. I’m going to start with Brian’s suggestion and go from there.
Old 09-18-2018, 07:45 AM   #9
And no I don’t have the cab over bunk. Just the cabinets and the TV.
Old 09-18-2018, 03:37 PM   #10
hook47's Avatar
Don't have the overhead bed either.
