Old 04-05-2016, 02:00 PM   #11
GM
bclemens's Avatar
It is designed that way...there should be a duct from the aquanaut specifically for the enclosed tank area.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
bclemens is online now   Reply With Quote
Old 04-06-2016, 08:19 AM   #12
FOURWHL's Avatar
Is there any way to set the rear camera display to be allowed during driving? Other than convincing the head unit the parking brake is set.
I can't imagine a rear view camera is any more hazardous to view while driving than the side views are, and they function no problem when the turn signal is on. When towing a trailer I really want to be able to see what's going on back there.
FOURWHL is offline   Reply With Quote
Old 04-06-2016, 08:55 AM   #13
halla's Avatar
Pioneer has a setting to leave it on. I know the sony did too, I just cant remember how to do it on the factory sony.
2016 Dynamax Force. Just-Rite2
2016 Dynamax Force---Just Rite 2
halla is offline   Reply With Quote
Old 04-06-2016, 09:21 AM   #14
I don't know what camera/Nav configuration you have, but our Nav has a camera function or a PIP function to view the Toad while driving.
dmax36 is offline   Reply With Quote
Old 04-06-2016, 09:25 AM   #15
FOURWHL's Avatar
It's a 2016 DX3 - Comes with the Sony XAV-602BT
But when driving it says "Video Blocked for your protection"
Old 04-06-2016, 10:16 AM   #16
Kenny kustom's Avatar
Couple ways to disable.
Sometimes easy as grounding the head unit park brake sense.
Some, need various flipping of switches.
Others, need a module.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Kenny kustom is online now   Reply With Quote
Old 04-06-2016, 10:17 AM   #17
GM
bclemens's Avatar
You would have to put a "hard switch" in place. That would trigger power to the reverse wire. I'll see about getting a diagram from my electrical engineer. The PIP function went away on the Excite head unit and some people were confused by all the features.
Old 04-06-2016, 10:21 AM   #18
New DX3 owner!
Pull the radio out, find the light green wire. Should be a long one.
Ground it. That will enable video in motion.
Brian is correct though.
Sony does not list a reverse wire, so I would assume it waits for a video signal to come from the back up cam.
The back up cam may be powered by the reverse lights.
Only issue is, if a hard switch is installed, it may turn on the reverse lights as well.
2016 Sabre 36QBOK
Old 04-06-2016, 10:36 AM   #19
FOURWHL's Avatar
OK. That's easy enough. Thanks guys!
Old 04-19-2016, 09:52 PM   #20
FOURWHL's Avatar
Got the camera working. Just needed to ground the light green wire.
Brake controller up and running as well. Nice job doing the hard work. Was a breeze running the wires from the tank into the cab.
Next question: what's this remote do?
