Old 04-19-2016, 09:55 PM   #21
GM
bclemens's Avatar
Awning. Need to pair it first.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Old 08-05-2016, 11:45 AM   #22
viperdave's Avatar
4whl - did you just ground the green wire permanently or put it to a switch when connects the ground? I'd like to be able to turn it on when making sharp forward corners to make sure that I do not hit my trailer just as I do in reverse. Thanks.
2016 Dynamax DX3
viperdave is offline   Reply With Quote
Old 08-05-2016, 11:54 AM   #23
FOURWHL's Avatar
Just grounded it and it worked fine.
I monkied with the spare switch in the dash but couldn't get it to work right and then when I grounded it everything worked so I took that as a sign.
2016 Dynamax DX3 - Big Blue
FOURWHL is offline   Reply With Quote
Old 08-05-2016, 12:09 PM   #24
viperdave's Avatar
ok I'll take a run at it. Thanks!
2016 Dynamax DX3
Old 08-10-2016, 09:01 AM   #25
viperdave's Avatar
Another spot on fix to resolve a helpful issue. Another must do for anyone with this unit.
2016 Dynamax DX3
Old 08-10-2016, 10:34 AM   #26
FOURWHL's Avatar
Yeah my display stays on the camera now while towing. Only chance to see what's going on back there really
Old 08-11-2016, 07:22 AM   #27
Hey_nav's Avatar
I need to look at this for mine as well and perhaps mod it as you guys have. For now, when I want a quick look at the toad I just hit the hazards for a few seconds when there is no one behind me. Mine is wired to show the rear camera when the hazards are turned on and gives me that quick warm fuzzy that the jeep is ok.
Gabe
2016 Dynamax Force 37BH HD
2016 Jeep Wrangler Unlimited - Rubicon Hard Rock
2016 = 160 days
2017 = 20 days
Hey_nav is online now   Reply With Quote
Old 08-12-2016, 08:52 AM   #28
viperdave's Avatar
its an easy fix then just a one button push to show camera. I put in a 7" Garmin gps so now I can see it better and do not lose gps when I turn on turn signals. Hardest part was finding a ground. There is non-used switch plug behind the dash with a good ground wire. I just plugged into that.
2016 Dynamax DX3
