You don't have to roll the school bus front end after all
I have ordered the bug cleaner. It should be at the RV campground in Portland by the time I get there on Sep 4.
The cannon would have to wait until I get home in Oct.
I have been using a waterless wash/wax solution while on the road. Works great.
Haven't tried it yet.
Just got it Monday at the campground in Wilsonville. Had our DX3 washed at a Blue Beacon when we came through Portland.
I'll let you know.
Not many bugs now, I guess because of the smoke from all the fires around here.
This clip shows the LED performance. While the light from the Max Output kit is quite amazing I believe most people will find the light from just two 10" Baja Designs LEDs will be a significant safety improvement over factory lights in low light destination camping situations.
Sharing a clear pic of the C9 grille sporting a Custom Badge and the Performance of 2 LEDs in the Main Grille. Dynamax does a great job including amber fog lamps so I didn't include a pic of the amber fog lamp performance.
The LEDs add a significant safety value when traveling off highway particularly as the days get shorter.
The photos were taken using a hi resolution camera with no edits (other than to add the text).
I need better lights. Pls.....What is the brand and where did you get them.
DL. I had the same issue with the headlights. I had these guys make a custom set for me. Much better. If you mixed them with the LED Grill lights, it would look like the sun coming up.
Does it replace the original headlights or built in the grill kit as a supplement?
Factory headlights are not altered. The LEDs are integrated into the grille kit. The location in the LEDs in the grille kit provides proper location for distance and spread of Baja Designs LEDs
Grille kit is triple chromed stainless steel and designed as an enhancement over the plastic commercial grille. LEDs are integrated into the grille to provide functional and safety benefits.
I had a place called HID Projectors make them. Here is a link to the page. They can pretty much customize them anyway you want, they buy a new set of headlights, make the retrofit and then ship them to you. I kept my oem headlights and switched them before I sold it. Now I can put them in the HD when it comes.
Just installed mine last Friday...same place Halla got his made. They now mount the ballast inside the housing so almost fully plug-n-play. I love them....can actually see the road at night [emoji1303]
I wondered'd who ordered the Buckeye colors. I don't think that was the plan...but it sure looked like it going down the line.
__________________ If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
