Old 02-04-2018, 11:00 AM   #1
Isata-3 FW
Jack McCord's Avatar
Next to Anderson valve - what is it? (Isata3)
What is this. It’s next to the Anderson valve and looks like a convenience light but the switch doesn’t seem to do anything.
Jack McCord is offline   Reply With Quote
Old 02-04-2018, 11:19 AM   #2
World Wide Wanderer
wahoonc's Avatar
Does the switch light up? If so that might be all it does. It could be a pump switch. Got a picture?
Aaron [emoji41]
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 02-04-2018, 11:25 AM   #3
Isata-3 FW
How to post a photo?
How do I post with a photo? I tried the phoyo icon but it then asks for a URL. But the photo is in a folder on my iPad and computer.
Old 02-04-2018, 11:37 AM   #4
Click on the paper clip above where you type, click on Choose a file. pick one from your computer, click on Download, click on Preview and see what you got! pretty simple.
Old 02-04-2018, 11:41 AM   #5
Walter Pigeon's Avatar
Below the panel where you compose your text there is a section "Additional Options" the second option down is Attach Files - click on the Manage Attachments in Grey and select the file from your computer to upload, click on upload and you can preview your picture when it uploads(You need to use the preview in the Options panel)
Hope this helps
Walt
Walt, Lanie and our fur baby "Foxie" loving life in the RV
2011 GEORGETOWN 337DS
Walter Pigeon is offline   Reply With Quote
Old 02-04-2018, 11:46 AM   #6
Isata-3 FW
What is it?
Old 02-04-2018, 11:50 AM   #7
Yes, It's an LED light fixture... Is there power to the fixture? Using a multi-meter check across the exposed leads on the switch... Did you take the len off ??
Old 02-04-2018, 11:51 AM   #8
Aaron [emoji41]
If it's a light, remove the cover and check the blub.
Old 02-04-2018, 11:51 AM   #9
Bill Davis's Avatar
Attachment 161667
What is it?
Looks like a light to me. Those yellow things look like LEDs.
Bill Davis is offline   Reply With Quote
Old 02-04-2018, 11:53 AM   #10
Attachment 161667
What is it?
That's an LED light. Check for voltage at the light. that will tell you whether it is the switch or the light.
Old 02-04-2018, 12:01 PM   #11
Isata-3 FW
Thanks. I’ll check the voltage. I didn’t recognize the LEDs.
Old 02-04-2018, 03:36 PM   #12
BobHanke's Avatar
There is another possibility that the polarity could be reversed which would prevent an LED from working.
"Lurch" = Georgetown 2011 330TS
Toad = Jeep 2016 Cherokee
Pilot = Bob
First Mate = Xiangbing
Crew = Radar, NiuNiu & NaNa
BobHanke is offline   Reply With Quote
Old 02-04-2018, 03:48 PM   #13
x2x2x2x2x2
Old 02-05-2018, 09:17 AM   #14
Commercial Member
Which switch are you using? I think they put a switch on the panel itself...but then there is a switch on the light (bottom). So could be the switch is off at the panel (or the switch is off at the light fixture). I just recall in a few cases the switches were redundant because we were using motion lights and if we ran out, we used the lights we put on the trucks. If that makes sense.
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Subscribe for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Sales-Service-Parts https://dynamaxcorp.com/contact-us
Old 02-06-2018, 06:36 AM   #15
srappleby's Avatar
If that light fixture is in a compartment then you may also have a switch somewhere else labeled "Compartment Lights". On my Legacy MH, I have to first turn on the "Compartment Lights" switch inside then, I can turn on any or all of the individual lights in each compartment as needed.
2014 Legacy SR300 340BH
2021 Jeep Gladiator
srappleby is offline   Reply With Quote
Old 02-06-2018, 09:50 AM   #16
Isata-3 FW
Yes, it’s in a compartment. I’ll search for another switch today.
Thanks.
Old 02-06-2018, 01:20 PM   #17
chroniekon's Avatar
Here's where my switch is on a 2017 Isata 3. (the little red square)
chroniekon is offline   Reply With Quote
Old 02-06-2018, 08:23 PM   #18
Isata-3 FW
I‘ll look again
I was there today but I didn’t see that. Of course I didn’t look there. I’ll look again on Thursday.
Thanks.
Old 02-08-2018, 03:39 PM   #19
Isata-3 FW
That’s it! Thanks. I never noticed that switch before. It’s right beside the water pump switch which I also didn’t know was there.
Much appreciated.
Jack
Old 02-08-2018, 03:45 PM   #20
Isata-3 FW
Thank you. Chroniekon had the answer. It was the black-on-black switch up in the corner, onlt 12 inches from the light. I had never noticed it before because I have to lean way down in order to see up there wherebit is very dark.
Thanks for you help.
Jack
valve
