I've used it many times, never heard it referred to as " kaisen foam ", but, that is correct. You will also find this material called, expanded polyethylene (EPE) foam, which is what I've always known this as. On the TT, I've used it to make plugs to block the heat from coming in the roof vents and skylights and to support my shower floor pan around the drains. It takes a lot of the movement out of it. The sky is the limit on applications for this stuff and easy to work with a sharp pocketknife
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
