Old 07-15-2017, 07:11 PM   #1
No power to T4 switch
The switch for the T4 satillite is located above the passenger seat
near the front tv in our ISATA 3. I set the Direct Tv receiver
and Swim. The receiver will send signal to the TV,? but I can't get the T4 to
power on. No power at the switch. Checked the fuse. Sat makes no noise.
ID:	144869 where does the factory splice into the hot wire to power the unit? Out of ideas what to look for.
TN Ranger is offline   Reply With Quote
Old 07-16-2017, 01:26 PM   #2
BClemens
Can you ask where the factory guys generally
pick up the hot wire for the sat. switch?
I can see a white and black wire but haven't found where the
hot is spliced into . Thinking it could be the receptacle that is
in the overhead cabinet beside the sat. switch.
Got everything else else hooked up but no power to the sat.
I think they ran the wire , maybe a bad splice into
he hot.
All this is based on the assumption the only hot wire is at the switch.
Thanks.
Old 07-16-2017, 06:47 PM   #3
Ours came without the switch (or the hole for it). The wires from the antenna were in the cabinet but no power wires. Factory sent the switch. Removed the USB receptacle located in the cabinet behind the switch and spliced into 12volt there. Bent a wire and fished the wires out where the rest of the wires enter the cabinet. Hope this makes sense. 2017 Isata 3,(no overhead bunk), some assembly required.
V8vic is offline   Reply With Quote
power, switch
