Originally Posted by mikew968
When I did the change on my 8kw Oman with a Kubota. Engine, the oem filter from the factory is not the filter you should use from then on. They use a smaller filter on the first one probably as the fist chance is at 50 hrs. I got mine directly from Cummins.
^^This^^
I did my 50 hour oil change a few weeks ago. I ordered the genuine Onan 122-0833 filter and when I pulled the original one out, it was significantly smaller that what I had ordered as a replacement. After some paniced googling, it turns out that Onan has superseded the original (small) filter to the larger 0833 filter.
Onan 122-0833
_is_ correct and despite whatever you might remove from your generator, rest assured that the 0833
_will_ fit. You cannot even buy the older smaller one any longer.
