Old 03-29-2016, 09:09 PM   #11
halla's Avatar
Horrible storm hit Orlando last week when we were at Disney. I was pretty sure there would be roof damage (luckily nothing happened). But we did have water come in from the rear AC unit. I think it was blowing in, but it was odd. I am hoping it wasn't a leak issue, only time will tell
2018 Dynamax Force HD BH---Just Rite-2
halla is online now   Reply With Quote
Old 03-29-2016, 09:48 PM   #12
GM
bclemens's Avatar
All those roof top A/C's are notorious for needing re-torqued. There is a foam gasket that seals to the roof. That can compress and shift if not tightened properly. I'll see if I can track down the spec, but that would be my first inspection
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 03-29-2016, 10:01 PM   #13
AWF1945's Avatar
Brian is correct, that's common on most motorhomes. Just dont over tighten them or they'll leak even worse... a little snug usually does the trick.
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
AWF1945 is offline   Reply With Quote
Old 03-30-2016, 06:46 AM   #14
halla's Avatar
I had also read on a few posts about the A/C unit that if there is high humidity, you have to turn the unit to high and not auto. When it runs on auto, the cycling can create condensation in the unit that drips out like a leak. So I will have to try to check the tightness and run on high during humidity.
Old 03-30-2016, 11:04 AM   #15
GM
bclemens's Avatar
We were running Atwood (and hope to be again, but they ran out during the Dometic purchase). This was their installation guide...4.4 ft lbs.
Old 03-30-2016, 02:11 PM   #16
halla's Avatar
Thank you for the help, will check it this weekend.
leak, slide
