Old 04-15-2019, 08:58 PM   #1
BSG
Power Help Please
So I have an Isata 5. Currently the panel or coach lights, etc. will not power up unless I run the engine. Coach batteries are not disconnected. No breakers are tripped. Batteries are charged. If I press the AUX 2 switch, the panel and lights WILL work without motor running. Weird as I thought that was for starting vehicle if chassis batteries were dead. So if I also start and run the motor the panel and lights WILL work. When I shut off the motor, power remains for another 5 or so minutes then everything dies. Even after it dies, I can still use the inverter to power appliances but no panel or lights etc. there is no charge if also running the generator. Who has the magic answer ??????? Thank you
BSG is offline   Reply With Quote
Old 04-15-2019, 09:16 PM   #2
By the panel, I assume you mean a Precision Plex panel, right?
Have you made any changes to your inverter recently?
steverkemp is offline   Reply With Quote
Old 04-15-2019, 09:22 PM   #3
Sorry for the dumb question, but how did you verify the batteries are charged?
Old 04-15-2019, 09:44 PM   #4
BSG
Yes the precision Plex panel. No changes to inverter
Old 04-15-2019, 09:45 PM   #5
BSG
When the precision plex panel is on (coach running) I can see both chassis and house batteries are charged. Also the solar panel charger shows as well
Old 04-16-2019, 01:12 AM   #6
Power Help Please
Here is a link to the electrical bay layout diagram (#17) . Make sure your battery disconnect isnít off. Did the dealer winterize your coach by chance and maybe turn it off?
Disconnect not working with Multi-plex (In Theory)
http://www.forestriverforums.com/for....php?p=1858754
Beyond this and Iím beyond my depth.
Old 04-16-2019, 07:56 AM   #7
western NC mountains!
formerFR's Avatar
The AUX switch simply connects the two different battery banks, the Chassis batteries and the House batteries, and the flow of power works both ways - whether you need the additional power to start the Vehicle, or to start the Generator, or to provide power to the 12v items in the RV, etc.
What the use of the AUX switch tells me, though, is that either you actually have the 'Use/Store' switch in the 'store' mode, the switch or solenoid for the 'Use/Store' switch is not working properly, or the House battery bank is very low.
I'm confused that the Inverter could still be powering the fridge - but, because it is a separate device, it may be attached to the House battery bank on it's own, bypassing the 'use/store' switch, and it may have enough power to continue operating, even though the 'use/store' switch's solenoid may not be staying latched effectively for the 12v items.
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx,
90,000+mi, US, Alaska, Canada, western NC for now : )
formerFR is online now   Reply With Quote
Old 04-16-2019, 08:56 AM   #8
GM
bclemens's Avatar
Aux 2 "connects the HOUSE and the CHASSIS batteries". So when you say "I thought it was used for starting" you are correct...if one set is dead, it connects them all together so you can use the other one to get started. IT SHOULD BE a momentary switch. You have to hold it down. If not, then it was likely changed to a constant switch in the up fitter settings.
If the lights are not running unless you start the engine, then that tells me (as others have mentioned) the house batteries are LOW or SHOT and when you start the engine, the alternator senses that and is charging the house batteries (thus providing 14 volts of power).
If you are using the multiplex panel to see the battery level...that will only tell you what they are if nothing else is plugged in and running. IF you have the engine running or are plugged in, then it is reading the charge line NOT the battery. If you have solar, it will read the solar charging voltage.
If you press the AUX 2 and the lights will work without the engine running, then you are using the Chassis batteries then (in parallel) to operate the house lights.
When you shut off the motor, then the device that connects the house and chassis batteries together for charging sees that the house batteries are low. It will disconnect everything to prevent you from draining the chassis batteries.
If you run the generator...it should be charging the house batteries ass long as the inverter is set properly.
Which inverter do you have? Xantrex or magnum?
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 04-16-2019, 09:01 AM   #9
caseymyers's Avatar
Great simple explanation of how my I5 works BD, thanks.
Old Navy Chief
2019 Isata 5 DS 4x4
2015 Jeep Rubicon Toad
Days camped in I5 2019 = 15
caseymyers is offline   Reply With Quote
Old 04-16-2019, 10:37 AM   #10
BSG
Where is the use/store switch. Are you referring to latch /momentary in AUX setup?
power
