Power share? On xantrex rs3000
We just purchaced a 2006 Grand Sport and I am a bit confused about the power share settings. Of what I can tell is on the control panel you can change the settings of amps. Does that mean that if I am on a 50amp plug site at a rv park that I should change setting on control panel to 50amp and then when its in storage on a 20amp service that I should change setting to 20amp and so on. And if so what setting should I use when using the generator 30amp or 50amp. Just used to less advanced motorhomes that you just plugged in to what ever amp service was availiable with out changing settings of any kind. Thanks.
