Originally Posted by bclemens
Could be an issue with the midi-module...or your power source. Also, is the Inverter set to only 5 amps??
Precision Plex might be the quickest to answer that question on the screen..but I seem to think it was the midi the last time.
I had my gen running and the two A/C on fan-low. Inverter was off. I did start a coffee pot and the current jumped to 12amps which seemed about right, so I know some parts of system are being monitored...seems like total current. Turned each A/C on then off and the current did change at the Control Panel for each action, so that confirmed it must be monitoring total current from both L1 & L2.
On shore power 30 amp: I know L1 & L2 would be tied together thru the dogbone, so nothing really significant can be drawn from that. Next time I get 50 amp shore power will have to retest.
As far as Inverter on/off did not impact current reported in Control Panel at all. That just tells me that sensor is before Inverter.
Located the midi module and I see it seems to only has 1 port for amps and two ports called Lin (I assume one for L1 and one for L2 ?) However, only have a comm cable plugged into one of the Lin ports. I don’t see any other loose comm cables laying around that should plug into 2nd Lin port (?)
So, I will just have to assume that this is just the way this rig is put together unless some other DX3’rs show something different.
