Old 09-10-2017, 12:16 PM   #1
Propane detector
Filled up my 2017 Isata 5 for the first time and now the co/gas detector will not reset and keeps on alarming. Anyone know what to do? I have had to disconnect it for some peace and quiet.
2017 Isata 5 DB
Teich is offline   Reply With Quote
Old 09-10-2017, 12:17 PM   #2
Filled with propane
2017 Isata 5 DB
Old 09-10-2017, 12:27 PM   #3
Mr. Dan's Avatar
Most of those detectors alarm on low battery, too. Mine did once. Check battery charge.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 14; booked = 42
Old 09-10-2017, 12:45 PM   #4
Oaklevel's Avatar
X2
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Oaklevel is online now   Reply With Quote
Old 09-10-2017, 03:58 PM   #5
halla's Avatar
Mine went bad after a month, I think it had dust in it or something. Replaced under warranty, no more alarms.
2018 Dynamax Force HD BH---Just Rite-2
halla is offline   Reply With Quote
Old 01-03-2018, 06:18 PM   #6
KRedburn's Avatar
Have same issue with my DX3. Filled with propane and now alarm is beeping all the time with a co light.
No propane is being delivered to stove or Aqua Hot
Have been unable to reset. It is 20 degrees here going colder tonight.
Any suggestions?
Ken and Kathy Redburn
2018 DX3 37TS (The Taj)
KRedburn is offline   Reply With Quote
Old 01-03-2018, 06:27 PM   #7
KRedburn's Avatar
Have checked voltage at the detector 14.3v
connected to shore power
does anyone know if propane solenoid is open with 12v applied or closed with no voltage or vice versa open no voltage applied closed with 12v applied?
Old 01-03-2018, 06:30 PM   #8
Any suggestions?
Disconnect the two white wires going from the detector to the inline solenoid valve by the propane tank. Gas should now work at the range. Run your range for about 15 minutes to burn off some gas. Sounds like your tank was overfilled. Should never fill more than 85%. Reconnect solenoid. Good luck 🤞
2017 Isata 5 DB
Old 01-03-2018, 06:30 PM   #9
With bottled systems it might be necessary to slowly open the valve from the tanks. Never had a MH system, but maybe the same thing could apply. There could be a safety shut with a rapid flow of propane. Open very slowly.
2018 DX3 37TS Sunset
rskeans is offline   Reply With Quote
Old 01-03-2018, 06:55 PM   #10
KRedburn's Avatar
Thanks Teich I cut the two white wires but that did not allow propane to flow. Had to connect 12 v to black yellow wire. Solenoid kicked. now have propane.
However, the stupid co alarm is still going off and won't reset. Currently inside of MH is same as outside air COLD! There is no CO inside this MH.
My only choice now is to kill the sensor. Not a real great comfort there. Will have to contact Dynamax in the morning.
This unit is only 4 months old. Not real happy right now.
propane
