Old 08-05-2016, 03:30 PM   #21
will try to check for propane at each appliance tomorrow, right now slightly storming here in central Florida, not a good combo.
Bill340 is offline   Reply With Quote
Old 08-05-2016, 04:31 PM   #22
Love my Rev
have you had this rv long ? just turn a stove burner on and lighting by hand to see if gas is getting there.
steve32409 is offline   Reply With Quote
Old 08-05-2016, 05:41 PM   #23
Had it since Dec. But just made a 30 day trip all worked well except the last week.worked one day drove 150 mi and never worked again. Have no gas stove.
Old 08-05-2016, 06:30 PM   #24
Since your trailer is new it sounds like something came loose
while you were travelling between campgrounds. Probably
not fastened properly at the factory. Have you tried crawling under
the trailer & following the propane pipe. Also if something came loose
in a manner of seconds all your propane would have escaped.
So if you still have gas then it has to be something right in the HWT.
Ian Walker is offline   Reply With Quote
Old 08-05-2016, 06:57 PM   #25
Update, storm has stopped so grabbed a neighbor to help turn gas off and on as I tested, Now have propane to the refrigerator, It works, have gas to the hot water heater valves, electronic spark clicks away but no propane to light, I have gas to the valve none coming out, when calling for gas have voltage at 8 watts on the terminals, other two are ground, also grounded good, I think this must be the culprit, as the gas wont come out, no clicking or vibration of any kind at this valve,Thoughts can't figure out how to add a pic of this valve, its a suburban Hot water heater in a Dynaquest 26
Old 08-05-2016, 07:25 PM   #26
Here is the valve mentioned above
Name:	propane valve.jpg
Old 08-05-2016, 07:48 PM   #27
Love my Rev
those elec valves not opening up to let gas through may or may not be the problem / if the water heater overheated , then there is a limit switch that kicks out and has to be reset ? BUT you are right there now !
Old 08-05-2016, 07:58 PM   #28
Love my Rev
I replaced one like that years ago for around $40 ( the whole unit ) because one of the solenoid went out
Old 08-05-2016, 08:01 PM   #29
Love my Rev
this may fit ?
Suburban 521073 Solenoid Replacement Kit For Seven Universe Direct Spark Ignition Water Heater Gas Valve Camper Trailer RV
Old 08-05-2016, 08:46 PM   #30
Thank all of you for your time and consideration, Will replace the entire valve as its 10 yrs old, Will let you all know how it ends,
Old 08-05-2016, 10:03 PM   #31
Love my Rev
exactly what I would of done
Old 08-06-2016, 04:23 PM   #32
How did you measure watts at the gas valve? Or was that just a mistype and it was really voltage?
If it was voltage, then 8 volts isn't enough to open the valve. If that's the case, you need to be looking for a voltage problem and not a gas problem.
Gotta go campin!
Old 08-07-2016, 11:57 AM   #33
Love my Rev
propane
