Old 08-03-2016, 09:33 PM   #1
propane no propane
Todays problem, We have a 2006 Dynaquest 260, we love this little bugger, just returned from a month long trip, Half way thru we lost our propane to the ref, AND the hot water heater, now the furnace runs on propane and the tank is full I ASSUME that the regulator is working as the furnace gets gas, we have no propane stove, just hot water,, ref.. furnace. Thoughts??
Bill340 is offline   Reply With Quote
Old 08-03-2016, 09:51 PM   #2
Just to be clear: How do you know the furnace is getting gas? Is it getting hot and running for more than a minute or two? If not, it may NOT be getting gas.
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 08-04-2016, 07:01 AM   #3
Head Rambler
If you're sure that the furnace is running, your description screams crimped line to me. especially since it was working and then it wasn't.
Do you know plumbing routing wise how the appliances are located in the line?
Is it cylinder > furnace > water heater > fridge?
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-04-2016, 08:16 AM   #4
Love my Rev
im confused
if you have propane and some things work - then you just have to see if you turned off a gas valve to that appliance or the gas valve in the stove quit working - just unscrew gas line nut to stove a little and see if gas is present.
steve32409 is offline   Reply With Quote
Old 08-04-2016, 02:55 PM   #5
Here's a crazy for you. May not apply but I've seen some crazy things in TT's.
Make sure you haven't blown a 12 volt fuse. The furnace won't run on gas & the fridge won't run on gas without the 12 volt hooked up.
Ian Walker is offline   Reply With Quote
Old 08-04-2016, 05:03 PM   #6
have propane to the furnace, turned the furnace on today lit right away blew heat, tested the lines for the water eater, no gas, checked everyfuse I could find all ok, have 12v to the fridge,ok, have voltage to the gas valve at the water heater, Have no gas stove, found in all this crawling around, behind the wall under the sink there is a 3in by 4in white plastic box with wires 4 on the bottom plug one red on the top, I think I could read something about a mother board, I know its linked some how. keep throwing Ideas I will keep trying..Thanks for all your help.
Old 08-04-2016, 05:24 PM   #7
Any chance your Propane/CO detector turns the gas off???
Old 08-04-2016, 07:01 PM   #8
Love my Rev
[QUOTE=Bill340;1280774]have propane to the furnace, turned the furnace on today lit right away blew heat, tested the lines for the water eater, no gas, checked every fuse I could find all ok, have 12v to the fridge,ok, have voltage to the gas valve at the water heater, Have no gas stove, found in all this crawling around, behind the wall under the sink there is a 3in by 4in white plastic box with wires 4 on the bottom plug one red on the top, I think I could read something about a mother board, I know its linked some how. keep throwing Ideas I will keep trying..Thanks for all your help.
-------------------------------------------------------------------Gas lines don't work like that , If you have gas ? and the gas tank valve is open - then all lines are open to the different appliances , fuses don't stop gas from going to each place. ( I would check your furnace again for flame and not just heat blowing - this is summer so make sure you have fire there)
Old 08-04-2016, 07:15 PM   #9
Love my Rev
on second thought - if you ran out , and then filled up - I just think you have air in the lines , so just keep trying to start things to get air through
Old 08-04-2016, 09:35 PM   #10
went to get propane just in case, only took 1 gal, ,its full was working fine one day, drove 150mi and turned on again no hot water or propane fridge,Started the furnace stood out side after a little the burner ignited and heat came pouring out of the exhaust, furnace works,
propane
