Old 10-25-2016, 09:21 AM   #1
FOURWHL's Avatar
PSA: When your pump keeps running
Had a fairly "duh" learning experience this last trip. Fired up the water pump and it just kept running. Ran around frantically for 10 min looking for where the water must be pouring out all over a place it shouldn't only to realize the city water was set to fill the tank. Seems it was able to suck enough air to not build pressure and turn off the pressure switch.
So if that happens check your fill valve!
Hope I didn't mess the pump up. Worked fine for the rest of the trip.
2016 Dynamax DX3 - Big Blue
FOURWHL is offline   Reply With Quote
Old 10-25-2016, 09:25 AM   #2
SeaDog's Avatar
the potable water pumps in most RVs now days are designed that they can be run dry without doing damage to the pump. Good heads up to others
Retired Navy
2016 Flagstaff 26 FKWS
Old 10-25-2016, 10:22 AM   #3
halla's Avatar
Thats one of those times you panic and it takes a while to figure it out. Happens to me a lot, lol.
2016 Dynamax Force. Just-Rite2
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
halla is offline   Reply With Quote
pump
