Question for Brian and the techs at Dynamax
I purchased the RVS rear view mirror replacement backup camera system. I'm looking to take my Isata 5 to a local shop to have the system installed but I was hoping to get a factory recommendation as to how to install the system.
I'm thinking that I can bring the camera feed wire through the front firewall, then along the underside of the chassis to the back drivers side corner. Then I would go up behind the drawers and up though the closet. I would then go above the ceiling in the bedroom towards the middle and see if I can feed the wire out the through the hole of the existing camera.
I think I can take the round vents off the ceiling and see if I can maneuver the cable to the spot I need.
Does this sound feasible or do you or one of your engineers have a better solution?
I would like to have an alternate solution in case the installer has a solution that I do not like.
Rob & Rosanne Rzasa
2017 Dynamax Isata 5 36DS
Towing 2005 Honda Big Ruckus
Go Gators
