Old 06-26-2017, 02:38 PM   #1
Radio Question
From my limited knowledge so far it appears that when you hit the driver's side disconnect, the cab is electrically dead. However I found an unlabeled switch that appears to bring the radio back to life. Now when we playing around with our unit this weekend, I think it went into demo mode each time we turned the cab on and off. So my question is the radio hot wire run straight to the battery? This would keep the presets and prevent the new radio start up screen.
houstonstroker is offline   Reply With Quote
Old 06-26-2017, 03:13 PM   #2
GM
bclemens's Avatar
What year and model do you have?
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 06-26-2017, 03:23 PM   #3
2016 force hd ts
Old 06-27-2017, 06:29 AM   #4
GM
bclemens's Avatar
That switch changes it from the chassis battery to the house batteries. If you disconnect the cab batteries you are cutting them off from everything for storage. So you would lose memory.
Old 06-27-2017, 06:49 AM   #5
AquaMan's Avatar
If you turn the radio switch on first, then disconnect the cab, will the radio retain all it's settings? Makes sense that it would.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 38
radio
