08-13-2018, 08:15 AM
Reinforcing DX3 Basement bin
Decided to add a green mountain grills pellet smoker to my kit this weekend. Trying to sneak it into the basement bin with my black stone griddle I noticed the bottom of the big bin had really started to bow. Even have some bow in the side walls. Guessing the 115 heat while loaded in Las Vegas didn’t help anything.
It was time to do a little reinforcing before I added another 68lb. Would’ve loved to have done it in aluminum, but I had a couple of sticks of 1”x1” steel laying around for another project I never got around to. Came out pretty good. Still debating on whether I fully cover it. Right now it’s plenry stout. I was able to fully support my weight with minimal deflection.
Right now it just sits in the bin. Transferring the weight to the walls is going to make a lot of difference I think. If I want to get crazy I can always run verticals and hang it from the steel that the bins are attached to but I’m not convinced that’s necessary. Going to run like this for a few trips and see how it does.
2016 Dynamax DX3 - Big Blue
08-13-2018, 08:39 AM
Nice, easy solution.
John and Susan Beard
2018 Dynamax DX3 37TS
2015 Jeep Rubicon Toad
Las Vegas, NV
08-13-2018, 08:51 AM
I was looking at the welds best I could see.. Nice job.
Formerly Mountieman
08-13-2018, 08:54 AM
If I had more time (read: was retired) I could’ve beveled the edges and made it pretty. Decided it will be covered in junk most it’s life so went for the down and dirty route
08-13-2018, 09:16 AM
Frog-Toberfest Organizer
Side question. How well does the bag work for carrying the Blackstone? How much room is in the bag once the grill is in it? I am thinking about building a custom box for mine (17 inch version). I want to be able to store the adapter and hose for mine when I switch to the quick connect system. If the bag will work I would rather just buy the bag.
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=57 '19=47 '20=47 '21=64 '22=62 '23=72 '24=0
08-13-2018, 09:25 AM
Sorry that’s just the cover draped over the black stone. I don’t have the bag.
I did also upgrade the cardboard I had been placing over the cooking surface to a piece of 1/2” plywood
Now the bag for the GMG is going to be awesome I think. Better chance to keep pellets and ash off my black stone.
08-13-2018, 09:53 AM
We have the 22" blackstone that comes with a stand. We store it all in the box it came in
Kevin & Jean
2018 DX3 37BH
08-13-2018, 10:42 AM
Great post! Thanks for sharing and looks great!
08-13-2018, 10:43 AM
I am currently putting mine in the cardboard box but it is slowly getting ruined. I wanted a tote but couldn't find one in the size I want. I may just make my own box so that I can get everything in it with a lid.
2016 Vengeance 320A
08-13-2018, 01:31 PM
Nice job. I would love to add a pull out tray in a few of the compartments, especially where my tools are. But I would want a low profile one so I don’t lose too much height.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
08-13-2018, 01:35 PM
Him, ours isnt that old so i guess that box will not last forever. If you find/make a solution please share!!
Kevin & Jean
2018 DX3 37BH
08-13-2018, 01:36 PM
That’s my on going struggle with storage in general. Added convenience decreases storage capacity. Whether it’s bins, drawers, whatever. But I agree. This would make a great base for a drawer. May try something in the front bin next.
Need to get all my gas cylinders moved to the top of the door also. Never realized how in the way they are til I removed this one.
08-13-2018, 05:05 PM
We have that exact same pellet smoker, love it, but it stays on our deck. We bought a smaller propane BBQ from CW that has a little drawer that you can fill with pellets if you want the smokey effect. It works really well too and a lot smaller to tote around.
Randy & Dee
2018 DX3 37TS
"Orange Crush"
08-13-2018, 05:26 PM
One word: Traeger
08-13-2018, 06:17 PM
I looked at the traegers but this one ended up fitting better. One inaugural smoke (tri tip and some sausage) so far and I’m pretty pleased. Going to do some ribs this weekend
I know a 28” black stone and this are overkill but we often end up as a base of operations for our wheeling group so being able to cook for several comes in handy. Good thing I’ve got a healthy CCC!
08-13-2018, 06:21 PM
Looks good, I reinforced with a plywood floor when I carried the Davy Crockett Green Mountain grill. I hope yours works better than the one I had. Would never keep the right temp setting and cooked to hot even when set to 180. Returned it under warranty.
Pat
2017 Isata 5
08-15-2018, 11:06 AM
I was under my rig this morning measuring for jack pads and was looking at bins that are not reinforced from below. Not sure you would want to go through the trouble but there is room to add steel from below and reinforce from there. I think it’s heat related myself because mine is new and some of them are sagging. May be a good winter project.
08-15-2018, 11:14 AM
Yeah there was somebody else that ran beam hangers from the frame and then unistrut underneath to the metal fronts. Definitely works also. I just wanted something I could weld so I didn’t have to run for hardware. Not enough room to access the steel frames between bins with them installed so I went interior.
Definitely agree that it’s heat related. And some of it just the fact that it’s plastic.
I just started to feel uneasy with that much stuff in there bouncing down the road. Probably as many peace of mind reasons as structural
08-15-2018, 12:06 PM
I did that on mine...got the idea from Houstonstroker, I believe.
Beam hangers on the frame and all thread down to unistrut cinched up tight against the bottom of the bins. Put two under each of the smaller bins and three under the larger ones...transferred all the weight/load to the frame. Also drilled holes through the strut once it was installed and bolted in tie down anchors in the corner of each bin and down the center of the larger bins.
Took about a day and a half to do it, but they can support A LOT of weight now.
2018 DX3 37BH
08-15-2018, 12:49 PM
Could you show some pics of how you did this please?
Formerly Mountieman
