05-27-2018, 03:49 PM
Replaced fuse - Don't know what it controls
While doing routine care I came across a blown 30amp fuse. Does anyone know what it controls? See Photo.
RV is a 2017 DX3 TS.
Tom
2017 DX3 TS
Tucson, AZ
05-27-2018, 04:03 PM
One way to find out is to pull the fuse and then see what doesn't work.
Slide(s), jacks, battery charge, lights, pump, awning, fans, etc.
Short of having an actual diagram showing what it protects, that's about all one could do. Flip every switch and try to operate every accessory.
05-27-2018, 04:06 PM
I wish I had a diagram for that fuse panel too. No idea what any of those do. I do know one of the 5 amp is for the RV step
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
05-27-2018, 04:25 PM
So nothing is labeled and no legend of any kind? Good grief, what kind of documentation do you actually get when you buy one of these?
05-27-2018, 04:32 PM
30 amps. No lights, pumps, awning, fans. Might be slides, levelers, or jacks. Heavy 12 volt load.
What wasn't working before you changed it?
05-27-2018, 05:39 PM
DX3 & Force fuse block
This might help
Cindy & Walt
2018 DX3 36FK
2015 JKHR - toad
05-27-2018, 05:45 PM
If this is the correct diagram, "Tow Charge" makes perfect sense.
If towing make sure connector and pigtail are wired correctly. I like to use a circuit breaker at the tower vehicle to protect the connecting wiring for flow in both directions.
If not towing, something may have shorted in connector.
05-27-2018, 08:29 PM
Originally Posted by CSWVK
This might help
05-29-2018, 12:03 PM
Commercial Member
yes, thank you. I was looking for that.
Engineering has started a pdf directory...but they don't have everything in there yet and changing EE's has set that back a bit.
05-29-2018, 01:32 PM
This might help
Brian,
Question on some of these Fuses.
SPR, CHS, Cons-1 (what do those designate?)
Tow Charge? (I am guessing this is the 12v line that runs to the trailer plug?
Tow Charge again in Relays?
Rearview Monitor? must be camera relay?
