Old 05-27-2018, 04:49 PM   #1
Replaced fuse - Don't know what it controls
While doing routine care I came across a blown 30amp fuse. Does anyone know what it controls? See Photo.
RV is a 2017 DX3 TS.
Tom
2017 DX3 TS
Tucson, AZ
tom234 is offline   Reply With Quote
Old 05-27-2018, 05:03 PM   #2
One way to find out is to pull the fuse and then see what doesn't work.
Slide(s), jacks, battery charge, lights, pump, awning, fans, etc.
Short of having an actual diagram showing what it protects, that's about all one could do. Flip every switch and try to operate every accessory.
I have it on my dog's authority that an afternoon nap is acceptable.
Politically Incorrect since 1943
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 05-27-2018, 05:06 PM   #3
halla's Avatar
I wish I had a diagram for that fuse panel too. No idea what any of those do. I do know one of the 5 amp is for the RV step
2018 Dynamax Force HD BH---Just Rite-2
halla is offline   Reply With Quote
Old 05-27-2018, 05:25 PM   #4
So nothing is labeled and no legend of any kind? Good grief, what kind of documentation do you actually get when you buy one of these?
Hsrvtime is offline   Reply With Quote
Old 05-27-2018, 05:32 PM   #5
cavie's Avatar
30 amps. No lights, pumps, awning, fans. Might be slides, levelers, or jacks. Heavy 12 volt load.
What wasn't working before you changed it?
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 05-27-2018, 06:39 PM   #6
CSWVK's Avatar
DX3 & Force fuse block
This might help
Name:	DX3 & Force Electric Bay Fuse  Block Relays Bird and 40 amp Mini Breaker.jpg
Cindy & Walt
2018 DX3 36FK
CSWVK is online now   Reply With Quote
Old 05-27-2018, 06:45 PM   #7
If this is the correct diagram, "Tow Charge" makes perfect sense.
If towing make sure connector and pigtail are wired correctly. I like to use a circuit breaker at the tower vehicle to protect the connecting wiring for flow in both directions.
If not towing, something may have shorted in connector.
Old 05-27-2018, 09:29 PM   #8
halla's Avatar
Originally Posted by CSWVK View Post
This might help
Old 05-29-2018, 01:03 PM   #9
GM
bclemens's Avatar
yes, thank you. I was looking for that.
Engineering has started a pdf directory...but they don't have everything in there yet and changing EE's has set that back a bit.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 05-29-2018, 02:32 PM   #10
halla's Avatar
This might help
Brian,
Question on some of these Fuses.
SPR, CHS, Cons-1 (what do those designate?)
Tow Charge? (I am guessing this is the 12v line that runs to the trailer plug?
Tow Charge again in Relays?
Rearview Monitor? must be camera relay?
fuse
