Old 08-11-2016, 10:41 PM   #1
REV 24 RB bed question
Brian,
Can the drop down bed in the REV 24RB be used at any height or must it be in the full down position?
Also, I am trying to locate the source of a squeak while driving. I think it is coming either from the dinette or the drop down bed. Can I drive with the bed in a lower position than full up?
The dinette table was raised by the dealer at my request. They added a 2x4 block between the bottom of the table and the post which may be the source of the squeak.
Thanks,
Bobby
2017 Dynamax REV 24RB
Delco Bobby is offline   Reply With Quote
Old 08-12-2016, 07:31 AM   #2
GM
bclemens's Avatar
I see no reason the bed could not be used at any position. It's basically a seatbelt strap un wrapping on a shaft.
As for squeak...the table bracket has a rubber ring around it that can be tightened down...make sure it is or I'm sure that could squeak.
You could easily disassemble the dinette top and leave it in pieces in a cabinet to rule that one out pretty quickly.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Old 08-12-2016, 12:30 PM   #3
Thanks.
bed
