07-16-2016, 06:02 PM
REV 24RB unplugged
These are photos of the area behind the sofa of my REV 24RB. Looking straight down towards the floor. For orientation the top of this photo is the interior side of the outside wall behind the sofa.
You can see an electrical plug that is not connected to an outlet. This may be the Truma heater. The black flexible hose appears to be the heater exhaust going to the outside wall of the REV. I don’t see an electrical outlet to receive this plug.
My recollection is that the heater worked during the PDI but it was a hot day.
My question is, what is this plug and should it be plugged in somewhere?
BTW, it doesn't look that dusty in real life.
Thanks,
Bobby
2017 Dynamax REV 24RB
2018 Ford F-150
07-18-2016, 05:01 PM
Commercial Member
I'll find out. The water heater/furnace runs on LP or electric. The ones we had before were LP only. I wonder if they were prepared for this new furnace.
07-18-2016, 05:16 PM
Commercial Member
I am told there should be an outlet on the galley wall. Might be hard to see....but should be there.
07-18-2016, 05:17 PM
Commercial Member
Actually, in your first picture on the woodgrain wall (left side) it looks like the bottom of an outlet...it would be a black plastic cover.
07-20-2016, 04:59 PM
Yes, it appears that once again you are correct. It is difficult for me to see but it looks like there is an electric outlet there.
I will see if my wife can plug the cord into the outlet. is there any reason not to have it plugged in?
2018 Ford F-150
07-21-2016, 11:19 AM
Commercial Member
No...should be plugged in to use all the features available.
07-21-2016, 01:07 PM
Good to know.
I guess the hot air it was blowing during PDI last month was just ambient temperature air.
Thanks.
2018 Ford F-150
07-21-2016, 02:08 PM
Commercial Member
No it could have been working on LP. There is an electric element option in the Combi. LP and 12V would still work just fine.
07-21-2016, 03:52 PM
Ahh, once again you are correct. The LP was on.
BTW, just for your info the Truma user manuals supplied are in Spanish or maybe Italian. No English.
2018 Ford F-150
07-21-2016, 09:51 PM
Yes, I have the flash drive. Supplying that is a nice touch.
The flash drive has the Truma CP Plus manual which is the remote control unit and display. i have not found the actual Truma manual on the flash drive. As mentioned before I do have that manual in a non English version.
2018 Ford F-150
07-22-2016, 07:27 AM
Thanks for the link. I couldn't find it on line.
2018 Ford F-150
07-22-2016, 07:32 AM
If I can impose on you again, i want the manual for the dometic air conditioner with the heat strip. The Dometic web site is a bit confusing, I am not sure which model I have as the serial number And model by Dometic's web site.
All I want is the instructions on using the A/C. All I found was how to install it.
2018 Ford F-150
07-22-2016, 08:58 AM
Commercial Member
If its the manual I am looking at, that is the "installation & operating instructions"
07-22-2016, 12:02 PM
Once again, thank you. That is what I wanted.
2018 Ford F-150
