Old 05-04-2016, 02:13 PM   #1
Betuski13's Avatar
REV 24TB Black tank flush
Howdy folks. I need some help. I want to use the onboard black tank flush on my 2016 REV 24TB. Can you tell me what position the Anderson valve should be in?
“Very little is needed to make a happy life; it is all within yourself in your way of thinking.”
― Marcus Aurelius
Betuski13 is offline   Reply With Quote
Old 05-04-2016, 02:54 PM   #2
GM
bclemens's Avatar
The Anderson valve would not do that. Should be another hose hook up on the sidewall of the coach.
Anderson Valve just sends water to the Pump, fresh tank or cold water fixtures directly.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 05-04-2016, 03:00 PM   #3
fonzie's Avatar
Your black tank flush is at the back, just hook up hose and open black tank valve.....see timeframe 1:11
Fonzie
Old 05-05-2016, 01:58 PM   #4
Betuski13's Avatar
Black tank flush method
Thank you. So the Anderson valve is independent from the black water flush? The method I have searched for online is as follows:
Black water slide valve closed.
Hook up a hose and regulator to the source.
Connect the other end to your black water flush.
Turn the water on and allow the flush to work for several minutes.
Open black water slide valve and empty.
― Marcus Aurelius
Old 05-05-2016, 03:21 PM   #5
GM
bclemens's Avatar
Yes, black tank flush goes from the outside wall, through a check valve, to the black tank.
Most of the warning stickers will tell you to have the black valve OPEN. A clear elbow on the sewer line is also nice so you can watch until water flows clean.
The issue with leaving the valve closed is if you walk away, tanks fill and stuff is everywhere.
black, black tank, black tank flush, tank
