Old 07-07-2016, 02:14 PM   #11
GM
bclemens's Avatar
On it...I think that's called "Arson" however.
In the meantime. Sanitubes / Sewer Hose Carriers / SUPER-TUBE - DW Inc.
Has a couple of options.
PLEASE do not send questions via Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
bclemens is online now   Reply With Quote
Old 07-07-2016, 02:15 PM   #12
Actually, a back bumper on the REV would be useful for the hose and inattentive drivers. I also found it was a half decent place to sit when I had my Sunseeker.
I don't think it would hurt the aesthetics of the vehicle.
2017 Dynamax REV 24RB
Delco Bobby is offline   Reply With Quote
Old 07-07-2016, 02:21 PM   #13
Good suggestion.
Old 07-07-2016, 02:47 PM   #14
Valterra makes one called the EZ hose carrier. It will get the job done but will required an email to Valterra.
So I ordered this from Amazon. When I received it noticed the mounting brackets were fixed to the tube. One at each end and one in the middle. How useless are non-movable mounting brackets if you mount the tube cross frame with typical trailer frame beams are 60" a part. So I emailed Valterra of the issues and they shipped me 2 of the center mounts. I secured them to the frame and then the tube to the brackets. Next issue is the RhinoFlex hose has barbs on the connectors don't fit in the tube. Just trim the with a hacksaw and they fit. The 96" tube will hold 2 sections of the RhinoFlex hose and the 90° end.
You can also get a square vinyl fence post and make your own.
BBQGUY is offline   Reply With Quote
Old 07-07-2016, 02:57 PM   #15
mvpmich's Avatar
Originally Posted by Delco Bobby View Post
clemens;1251302]Oh those stupid, careless and ignorant RV designers.
1. we don't design it. That is a stock part that just plugs in there. Blame B&B for the outdated design...blame mfg's for not taking something off that has been there for years that no one uses.
2. I compare it to ash trays/lighters in cars. its there, because everyone has just always put it there. Everyone used to use the blue hose and it fit. Might not have made any sense then, certainly doesn't now.
My goal was to replace it with something...but you tell me what? I've looked. There is nothing deep enough due to the frame of the chassis. No one makes anything that is curved.
On our trucks, we have a nice big storage tube that holds the hose and fittings and mounts to the utility compartment door. But these new hoses are big and with the fittings even bigger. What we need to do, is just have a compartment instead and clearly mark it for sewer hose storage, but then I wonder if we get complaints that we're wasting a perfectly good storage compartment for a sewer hose.
Dynamax could lead the way by incorporating a black tank contents vaporizer. Push a button and zap the contents. Maybe in the next century...[/QUOTE]
No need for sarcasm. Other manufacturers have better designs. Such as;
https://www.google.com/imgres?imgurl...act=mrc&uact=8
mvpmich
2012 Sportscoach Cross Country 385 DS
Freightliner XCR w/ Cummins ISB 6.7L 340 hp
2009 Saturn Vue, Blue Ox Alpha, RVi Brake 2
mvpmich is offline   Reply With Quote
Old 07-07-2016, 03:10 PM   #16
All of those are very nice but none will fit in the smaller Dynamax offerings without losing precious outside storage space. It seems to me a larger vehicle is needed to accommodate these good ideas. Maybe I should have bought the Georgetown that I like.
Old 07-07-2016, 03:10 PM   #17
We could go on for days about what is designed and installed on an RV that is not functional or is a bad design. Saw a post a few days ago that recommended an RV designed should be required to use the RV for a while then things like the outdated, to small, sewer hose carrier would be there and a usable one would be.
Own a Puma 359THKS. On the water heater cover it says "HOT! DO NOT BLOCK" but for some reason the designer placed the power input receptacle and the city water connection directly above the water heater. The power cord hangs across the very hot exhaust vent. What was he/she thinking?
Old 07-07-2016, 03:18 PM   #18
mvpmich's Avatar
Interesting. You should have read my entire post as I have a 40' Sportscoach DP with little or no room in the wet bay and the swivel holder below. I made it work but the ability to have more room in the bay would have solved most of my problems.
mvpmich
Old 07-07-2016, 04:30 PM   #19
GM
bclemens's Avatar
To be fair, this is our M2 Freightliner set up. Thetford Sanicon Turbo. All the hoses stay connected (not shown at this stage) and coil right up in the wet bay. No issues at all.
Small stuff (Isata 3, REV) is another story. I just went and looked again. On the Isata 3, the whole side is filled with compartments, or propane or holding tanks. The only place to put the sewer hose holder (that's too small) is right where its at...sandwiched between a holding tank and the propane tank. And can't go any deeper due to the frame rail. So we could delete it and save the confusion...but nothing else will fit there. And as I have always said..."its only wasted space if you don't use it"
previous division we had a little cabinet that took advantage of some "wasted space" that housed our electrical equipment at the top. So we put a door on the cavity that was created below it. It was only about 4-5" deep, 15" wide, 36" tall...but boy did people complain how that was a worthless cabinet.
I'll look at the REV again...but we tried a "flex version" that was corrugated aluminum and it would bend and extend to fit bigger hoses. It just wasn't very durable. What we really need on the small stuff is a larger diameter tube with a 90 degree sweep so that it goes in and runs along the frame rail.
Old 07-07-2016, 04:53 PM   #20
I like the idea of having the hoses always attached. As long as they can be disconnected for replacement and cleaning if necessary.
