Old 07-27-2016, 09:21 AM   #51
Love my Rev
And now on to the next small deal - "my awning " rolled it out for the first time camping and it looked so low on right side that it was embarrassing , tried to roll it back and had to push it with a broom - lol ( the right brackets look real loose ) hope that is it ?
steve32409 is offline   Reply With Quote
Old 07-27-2016, 10:25 AM   #52
GM
bclemens's Avatar
brackets/bolts going into the wall?
There is a pitch adjustment that can be done. I don't like the sound of "loose against the wall". Pitch adjustment is somewhat easy, if the mounting plate is loose, it sounds like the installer might have missed the backer. In one year, I have seen ONE this way and it was the front one. It looks like they knew because there was a washer on that bolt...I was NOT a happy camper.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
bclemens is online now   Reply With Quote
Old 08-25-2016, 10:40 PM   #53
Hi bclemens...maybe you can answer this question. We recently ordered a 2017 Isata 3 RW and was wondering how deep that sewer hose cavity is and it's diameter? We normally use a 15' RhinoFlex hose that compacts to 56", but the hose has adapters and elbows already attached (they can be removed). In the past, the hose would easily fit in a 4x4" bumper storage. The holder looks wide enough to hold it, but when we saw the floorplan, we did not get the measurements. We are so looking forward to getting our new rig. Thank you!
blanics is offline   Reply With Quote
Old 08-26-2016, 07:31 AM   #54
GM
bclemens's Avatar
Its not anywhere near 56". We're limited to the depth from the sidewall to the chassis frame rail which is about 36", give or take. We've been looking at lots of alternatives but none of them seem to be fitting the bill.
I will say, the 24RW has a generous amount of storage for a small unit and there are several smaller compartments that could work for storage of the hose and other utility items.
Old 08-26-2016, 09:22 AM   #55
Thank you for your quick response...a 10" RhinoFlex compresses to 32", so it may fit, which would be nice. As we will be traveling 6 months out of the year, bin storage in this small rig will be at a premium...hate to use some of it for sewer connections.
