Originally Posted by steve32409
All I do is drain water tank by small turn valve underneath , then put my 2 ft. hose in a gal of " pink stuff " / turn my water valve to " winterize and open all faucets and stool one at a time until pink flows / and it takes less than one gal.
I drained the FW tank, Truma Combi heater and the two low point drains were opened. They were all open for two days. I had a short drive but didn’t have the opportunity to take a long drive. I live in a hilly area which helps to drain the water on longer drives.
I used about 3 gallons or maybe a little more of anti-freeze before pink came out of all faucets. The Anderson valve was sey to Winterize. I used the same amout in two previous years. No pink stuff was wasted by me forgetting to close the open drains. This year my wife helped me on the inside which saved me running in and out to change the bottles as they emptied.
My water lines may be longer than yours?
