Old 05-10-2018, 03:16 PM   #1
2018 Isata 5 30FW
Rough ride
I have a new Isata 5 30FW. I love the coach except for the stiff ride. The chassis is a Dodge 5500. Any ideas or recommendations?1
Space Cowboy is offline   Reply With Quote
Old 05-10-2018, 05:14 PM   #2
On my '14 3500 RAM dually the ride improved by changing the OEM shocks to Biltstiens.
2018 DX3 37TS Sunset
rskeans is online now   Reply With Quote
Old 05-10-2018, 05:22 PM   #3
GM
bclemens's Avatar
I know we used to have an issue on the E450 vans. Loaded, the vehicle rode great. But the smaller and lighter it got, the rougher it rode. best bet was to travel with full water and gear.
I get zero complaints on the 36DS, but that is also bigger and heavier than the 30...so I wonder if that might be part of it. Are you loaded up or just on the drive home?
Secondly, 99% of the time on the M2 chassis...rough ride was always tire pressure related. We ship the unit with MAX pressure, not knowing how you will load it. You should adjust your pressure based on actual load and not maximum load.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 05-10-2018, 06:09 PM   #4
Webefine's Avatar
I was going to mention tire pressure but Brian beat me to it. Get your rig weighed when it is loaded and ready to travel and set your air pressure in your tires from the tire pressure chart for your tires.
Webefine is offline   Reply With Quote
Old 05-10-2018, 07:48 PM   #5
Agree with all. I've had a 3500 RAM for 8 years and 100,000 miles and it's about tire pressure. Figure out the sweet spot for your load and it will handle well and ride much better. And it all depends on your load.
Old Navy Chief
2019 Isata 5 DS 4x4
2015 Jeep Rubicon Toad
caseymyers is offline   Reply With Quote
Old 05-10-2018, 08:06 PM   #6
2018 Isata 5 30FW
Thanks for the replies. I did check on the Bilstein shocks but they don't make one yet for the 5500. I did weigh the rig right away with full fuel, water, lp, def and myself. The steer axle was right at its max at 7,250#. The rear axle was at 10,600. So I still have approximately another 1,100 carrying capacity. The tires are at 95 lbs which is what the label on the left door jamb states. I've checked on the Liquid Spring system and found out it's very pricey. So I'm trying to learn what others have tried. I've driven many rigs over the past 40 plus years and have been spoiled. My first choice of coach was the Freightliner chassis, giving me diesel power and air ride. Too big for my wife so we settled on the Isata 5. I got the diesel power I wanted and my wife got the size she wanted. In a quest to smooth the ride. Thanks again.
Old 05-10-2018, 08:56 PM   #7
My wife was also intimidated by the Freightliner until I pulled off the interstate and said get behind the wheel. I spent about 5 minutes explaining everything. She drives our big RAM dually without any probems. I just explained that this is just a little larger than the RAM. The back follows the front. She drove it for the next 100 miles. Confidence is way up. She is not ready for the city yet, but in time. BTW, she is 5'0" and pushing 80 years!!! She drives our RZR (rolled it over once). We uprighted it and she got right back behind the wheel.
Old 05-10-2018, 09:02 PM   #8
2018 Isata 5 30FW
It's not an intimidation issue. We like to go to county and state parks as much as possible. 30-32 foot seems to be the limit, for some national park sites too.
Old 05-10-2018, 09:12 PM   #9
I agree with that. If the ISATA 5 had a washer/dryer we'd be driving that
Old 05-10-2018, 09:43 PM   #10
dlfishing's Avatar
Get on line and look up the pressures for exact tires you have with the weights. Will be more accurate than the door label. That chassis is built for many different vehicles
I use 80 psi in my DX3.
dlfishing is offline   Reply With Quote
