Old 07-16-2018, 08:01 AM   #1
RV fridge in Force HD
Does anyone else have the optional Norcold RV fridge in their DX3 or Force?
I think mine is not wired correctly.
When I remove the AC power the fridge continues to run on AC even though it is set to auto and the propane is turned on at the tank.
This causes the batteries to go to 11.8 volts in about 8 hours and it still doesn't auto switch to propane.
I believe it is on an inverted circuit and should not be.
djmedel is offline   Reply With Quote
Old 07-16-2018, 08:20 AM   #2
SeaDog's Avatar
You can test your theory by unplugging the 110V power at the frig and see if it switches to gas and your batteries stay up.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 07-16-2018, 08:33 AM   #3
GM
bclemens's Avatar
All our Fridge circuits are inverted. You would want to put the fridge into LP Only mode.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 07-16-2018, 12:43 PM   #4
Brian,
I think that the RV type fridge should not be on an inverted outlet.If you lose AC power it draws 50 amps from the batteries and drains them quickly.The refer has the ability to automatically switch to propane when in auto mode, so one less thing to think about when moving from place to place or camping without hookups for a night or two.
Old 07-16-2018, 12:51 PM   #5
GM
bclemens's Avatar
opinion duly noted.
You could also just turn off the inverter. Maybe that is simpler? The problem with not inverting it, is if there was ever a reason you wanted it inverted, you have no options. Having it inverted means you could (maybe ran out of LP) use the inverted circuit. While this way does require some more user input, it gives you maximum flexibility.
For rigs like the DX3, we invert the entire coach. So to take out one outlet in the rare instance we do an RV fridge, is asking for errors.
Old 07-16-2018, 12:57 PM   #6
western NC mountains!
formerFR's Avatar
I'm not sure why someone would not WANT it to be on the inverter, as any residential RV fridge is. It also does NOT draw 50amps, wherever that came from(?), but only about 3-8amps depending on the size and type...and it only uses 'amps' when the compressor is running, not 24/7... typically only about 10 minutes at the time, several times per hour.
In your situation, you wouldn't want to use 'auto' if you have your inverter on, as the fridge is still 'seeing' 120v power, if so.
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 200w/10amps mobile SOLAR
90,000+mi, US, Alaska, Canada, western NC for now : )
formerFR is online now   Reply With Quote
Old 07-16-2018, 03:11 PM   #7
There is no compressor on my absorption fridge
Old 07-16-2018, 03:27 PM   #8
formerFR's Avatar
I guess my point is that your fridge will actually draw much less than what you think, when on 120v power from the inverter, especially since it doesn’t have a motor(compressor)... you could last even longer on the inverter than most of the rest of us : )
Old 07-16-2018, 03:32 PM   #9
I checked the 12 volt side going to the inverter with a DC ampmeter and it reads 48 A with only the fridge running
Old 07-16-2018, 03:40 PM   #10
formerFR's Avatar
gotcha, but that’s 48amps at 12volts, not at 120volts for the inverter, Shore, or Gen power... but the conversion would be at only about 3-4 amps.
if you have just a single 12v 100ah house battery, you could easily run the fridge for 10hours, without being down to 50% battery capacity
fridge
