Originally Posted by bclemens
"The process required for adding in the field would be:
1. Pull the cover off
2. Remove the factory foam pack
3. Position where you want the arm bracket (they use some jig) and then weld it on
4. Cut foam out around where the bracket goes and then put the foam back on the chair
5. Reupholster the chair and the new arm"
They say it is not something that someone who is not well versed in this should do...but they could supply the arm and cover if they had to. I'm not sure if they "hog ring" the cover or it it uses the newer clips.
That will be fine with me, one of my neighbors works at a local trim shop so I have both the welder and the upholstery guy ready.
One left and one right armrest when you have the information and the stock please.
