Old 03-13-2019, 10:09 AM   #1
Shower conversion? Isata 3 RW
Brian mentioned a year or so ago that they were looking into a shower conversion kit for the Isata 3 RW - to remove the shower curtain and install a door of some sort. Has this become a reality? The only thing we donít like about our coach is the shower curtain, which we HATE! With the way the curtain grabs our legs when showering, it decreases the space by 1/3.
Thanks, Sandi & Gerry
altlamp is offline   Reply With Quote
Old 03-13-2019, 10:50 AM   #2
Magnatudes's Avatar
Originally Posted by altlamp View Post
Brian mentioned a year or so ago that they were looking into a shower conversion kit for the Isata 3 RW - to remove the shower curtain and install a door of some sort. Has this become a reality? The only thing we don’t like about our coach is the shower curtain, which we HATE! With the way the curtain grabs our legs when showering, it decreases the space by 1/3.
I don't have a good photo of my solution to hold the curtain away while showering. The best I have is below. I used a PEX tubing (red tube in photos) about 4ft long and shaped it to push against the curtain for maximum space inside the shower. This holds the curtain away so it doesn't cling to your body. I installed a PVC fitting near the bottom of the shower at the exterior wall and another fitting about midspan in height against the bedroom wall side of the shower. The red PEX tubing is removable. Over time the PEX took the desired twist & bend and is easy to install & remove while inside the shower stall. Hope this gives you some temporary relief to this annoyance.
ID:	198652   Click image for larger version
ID:	198654   Click image for larger version
2018 Isata 3 24RW
Downsized from 2004 Country Coach Intrigue
Magnatudes is offline   Reply With Quote
Old 03-13-2019, 11:19 AM   #3
Originally Posted by Magnatudes View Post
I don't have a good photo of my solution to hold the curtain away while showering. The best I have is below. I used a PEX tubing (red tube in photos) about 4ft long and shaped it to push against the curtain for maximum space inside the shower. This hold the curtain away so it doesn't cling to your body. I installed a PVC fitting near the bottom of the shower at the exterior wall and another fitting about midspan in height against the bedroom wall side of the shower. The red PEX tubing is removable. Over time the PEX took the desired twist & bend and is easy to install & remove while inside the shower stall. Hope this gives you some temporary relief to this annoyance.
Thank you! Weíll try that.
Old 03-14-2019, 02:22 AM   #4
GM
bclemens's Avatar
No, the supplier was working on a plastic shower curtain similar to the one we use on the FW, but they never came through.
We're working on a redesign on the 24RW to see if we can get a shower like the 24FW,...sink would likely move outside the bathroom.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 03-14-2019, 08:46 AM   #5
Not what I wanted to hear, but thanks for the reply.
Old 03-14-2019, 03:22 PM   #6
I have a few questions about your modification to the shower. This has been a pain for us too. Did you find it worked best to keep the shower curtain away from you body by having one of the fittings at the bottom and the other mid-way up on the opposite wall? Did you think about putting them both near the bottom? I'm assuming the PVC fittings are standard PEX type fittings? With the shower curtain pushed out with the PEX does this cause any water to get out onto the bathroom floor. I definitely want to try this modification too, thanks for posting.
dr911 is offline   Reply With Quote
Old 03-14-2019, 05:27 PM   #7
Magnatudes's Avatar
ID:	198762   Click image for larger version
ID:	198763   Click image for larger version
ID:	198764   Click image for larger version
ID:	198765   Click image for larger version
2018 Isata 3 24RW
Old 03-14-2019, 06:55 PM   #8
Thanks for the new photos!
Old 03-15-2019, 08:53 PM   #9
We use 2 small bungee cords with alligator clips. Just clip it to the curtain before getting in. Click image for larger version
janeenb is offline   Reply With Quote
Old 03-15-2019, 10:25 PM   #10
Originally Posted by janeenb View Post
We use 2 small bungee cords with alligator clips. Just clip it to the curtain before getting in. Attachment 198855
Thanks! Another good idea!
show, shower
