Old 05-02-2019, 03:58 PM   #1
BellaBee's Avatar
Shower not draining...ideas?
Hello,
We are in our shakedown cruise and have an issue with the shower not draining?
It was intermittent once or twice the first couple is weeks but now is not draining. It will drain extremely slow if left alone.
I’m not sure about the trap system so I haven’t tried disassembling anything yet. It’s not clocked with hair or other stuff. I feel like maybe something could have been left from the production process.
Also, in looking at the system I also noticed the factory did not properly mount the sensors on the grey tank. In fact there are three sets of sensors on the black tank. Go figure. I’ll have to sort that one out later. Any pics of an XL 37RB black and grey tank with the sensors properly installed would be much appreciated.
Thanks,
BellaBee is offline   Reply With Quote
Old 05-02-2019, 04:30 PM   #2
hook47's Avatar
Grey tank isn't full, is it?
2018 DX3 37RB - 2017 Jeep GC Summit towed
hook47 is offline   Reply With Quote
Old 05-02-2019, 04:36 PM   #3
Trailer Park Supervisor
NJKris's Avatar
There should be. One for 1/3 full, 2/3 full, and one for full.
Yes, I drink the water!
NJKris is offline   Reply With Quote
Old 05-02-2019, 04:37 PM   #4
NJKris's Avatar
What is your gray tank level? The shower will be the first place it backs up if it is full.
Old 05-02-2019, 08:00 PM   #5
Commercial Member
I believe we are running the Hepvo valve on all showers now...could be debris. Have you tried a plunger? to see if you can work it through?
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Subscribe for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Sales-Service-Parts https://dynamaxcorp.com/contact-us
Old 05-03-2019, 01:28 PM   #6
Orangeman's Avatar
For anyone who doesn't know what that is or does ....
Orangeman is offline   Reply With Quote
Old 05-06-2019, 02:23 PM   #7
BellaBee's Avatar
Tried the old plunger process and it worked. I just wasn’t sure you could use a plunger on an RV plumbing system. I have noticed there seems to be “some stuff” being ground up in the macerator when I dump the grey tank. Happens near the end of the dump cycle. Much appreciated.
Now I need to get the sensors installed by moving them from the black tank.
Cheers,
Sal
_____________________________
Sal & Teresa
2019 Dynaquest XL 37RB Midnight Sapphire
2019 Jeep Wrangler
USN Veteran (USS Saipan, VAQ-34)
Old 05-06-2019, 02:32 PM   #8
Originally Posted by bellabee View Post
tried the old plunger process and it worked. I just wasn’t sure you could use a plunger on an rv plumbing system. I have noticed there seems to be “some stuff” being ground up in the macerator when i dump the grey tank. Happens near the end of the dump cycle. Much appreciated.
Now i need to get the sensors installed by moving them from the black tank.
Cheers,
sal
not sure why you are wanting to remove the sensors???
gbaldwin is offline   Reply With Quote
Old 05-06-2019, 02:34 PM   #9
Cheers,
Sal
I didn't see where you said if you have a 2nd grey tank (galley) for the kitchen but in any case if the kitchen "stuff" is going into your grey tank, you need to be diligent about scraping/wiping the food particles off any plates, pots and pans before washing/rinsing in the sink.
I've seen grey tanks that were worse than black tanks.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 05-06-2019, 10:25 PM   #10
BellaBee's Avatar
The sensor issue is I have no level sensors on the grey tank. I believe the factory made a mistake and installed all the sensors on the black tank. Trying to sort that out now. Should be an easy fix. I just need to figure out which sensor belongs to the black and which set belong to the black tank. Thx
Sal & Teresa
2019 Jeep Wrangler
Old 05-06-2019, 10:52 PM   #11
BellaBee's Avatar
This was very helpful to learn about how that valve works. I noticed it when I removed the access panel. I had no idea what it was for or how it worked. It's clear from my situation that something was keeping that valve closed since when I started the water in the shower it started to fill up right away. Since that valve is connected right after the right angle connector to the shower drain I suspect something was keeping the valve from opening. Once I plunged it a few times it water began to flow properly. My hypothesis is something used in the shower could be making that valve sticky. Seems strange but we'll see as we continue to use the shower. Since I now have a plunger, I should be able to fix that quickly if it happens again. Thanks again. Much appreciated.
Sal & Teresa
2019 Jeep Wrangler
Old 05-07-2019, 08:59 AM   #12
Commercial Member
I think those things come in slightly powdered...but I wonder if someone poured antifreeze down that trap like normal. Maybe that antifreeze gets sticky when it dries?
Old 05-07-2019, 09:11 PM   #13
BellaBee's Avatar
"Antifreeze like normal"? I'm not sure what that means. Is this a process done at the factory during installation and testing?
Regardless, the plunger did the job to unclog whatever was causing the issue. I'm pretty confident it was something in that valve given how fast the water would back up.
Thanks,
Sal & Teresa
2019 Jeep Wrangler
Old 05-07-2019, 09:46 PM   #14
DieselDrax's Avatar
Thanks,
YouTube “RV winterizing” to see examples of how to winterize if needed where you live. RV antifreeze is pumped into the freshwater lines and poured down the drains to displace the water sitting in the P traps that can freeze can crack the pipes.
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
DieselDrax is offline   Reply With Quote
drain, show, shower
