07-05-2016, 08:38 AM
Slides and jacks
Here's a chicken and the egg one:
What comes first when you setup: Slides or jacks? Does it matter? Ok to use slides without the jacks down?
07-05-2016, 08:42 AM
Slides on my unit do not move until it is level and jacks are down.
07-05-2016, 08:45 AM
That is a Easy one to answer,if the slide needs to be deployed to use the "Bathroom" I would Not wait to put the Jacks down! Youroo!!
07-05-2016, 08:49 AM
Haha thankfully everything, especially the bathroom, are fully usable with the slides in!
Slides on my DX3 do work as long as the engine isnt running, even on battery so no limits to needing the jacks down that are hard wired.
I've done it both ways, but was just wondering if there's a preferred method really.
07-05-2016, 09:04 AM
Jacks and level, then slides.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
07-05-2016, 06:31 PM
Jacks and slides. Our dealer suggested slides then jacks due to the weight of the slides extended could throw off the leveling, but I have not seen the level change after we deploy the slides.
2016 Dynamax Force. Just-Rite2
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
07-06-2016, 02:52 AM
I level first, and then deploy slides.
Mike
2016 Force HD
Mike
2016 Force HD 36
07-06-2016, 03:05 AM
You should always be as close to level as possible before you use your slides, the reason is they could bind on you if your not. In Youroo answer it's true because you should be pretty level when towing on flat land. Mine I have to open to get into the refer when traveling, but I make sure I'm on level ground when I do open it.
Coachmen M/H
Concord
2018 / 300 DSC
07-06-2016, 11:27 AM
I made a procedures checklist and put the level before the slides. It just made sense to me from a time management standpoint. I get what your saying about the actual level though but I haven't seen it be an issue yet.
Newbie
2 RV Trips to date
19 States
2016 Dynamax Force HD
07-09-2016, 10:07 PM
Attachment 113247
Newbie
2 RV Trips to date
19 States
Then get adult beverage
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
07-10-2016, 04:26 AM
Attachment 113247
Newbie
2 RV Trips to date
19 States
I pretty much do the same just in a different order. FIrst thing I do is pull into the site and check for my slides clearance and how level I'm at incase I have to move it a little, I have pulled in and did all above and found I couldn't deploy the slides or awnings. Dumb, after I had to re hook eveything back up I learned that lesson. And yes I did add sit and have a beer at the end also... PS: some of the old parks where not built for slides they where built before slides came out and never been retrofitted to accommodate.
Coachmen M/H
Concord
2018 / 300 DSC
