Old 08-21-2015, 08:34 AM   #1
GM
bclemens's Avatar
Sprinter is slowly coming along.
It has walls. Just a few things that Dynamax does differently than most mfgs.
1. All of our walls are built and framed in aluminum, in their entirety. In some cases a mfg will build the wall and slide rooms separately. We build the slide room, right inside (and welded to) the main wall. Once the floors, WALL and roof are set, we cut out the slide room wall to assemble the slide box. That assures that everything is square and solid prior to pulling out that big hole. Then the slide boxes are assembled and the slide room will go right back inside that same unit it was cut out of.
2. All the slide rooms are painted "Prior" to the slide being installed. Again, this does a few things. It allows us to paint all the way to the edges. No trim or tape to cover the areas that could not be painted. Also it reduces the chances of overspray on the slide seals and inside the motorhome.
More to come.
Name:	2015-08-19 16.03.46.jpg
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 09-17-2015, 12:36 PM   #2
RedLdr1's Avatar
How about an update? You have me curious...as that looks like a "W" on the drivers side!
Wayne and Christine
2019 Sunseeker 2500TSF Pending Delivery...
2018 Ford Focus SEL Hatchback TOAD
RedLdr1 is online now   Reply With Quote
Old 09-17-2015, 12:41 PM   #3
GM
bclemens's Avatar
lol. Good eye. I'll see about a sneak peek today. Just came out of paint.
Old 09-17-2015, 02:19 PM   #4
GM
bclemens's Avatar
Well, they still had the front masked off...but we'll show off a little hand sprayed drop shadow that I don't think anyone is doing currently. Carefree, two stage legless awning with motion sensor.
Should have interior and exterior pics by the end of next week.
Old 09-17-2015, 07:26 PM   #5
Campin Cajun's Avatar
I like that paint job, looking good.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
