Old 04-20-2019, 08:51 AM   #1
Stopped up toilet
Camping here in Katy and the toilet in our 2018 Force has stopped up. It was draining really slow until we took a water hose to it to try and force the clog down. Now it won’t drain at all. We also tried pouring really hot water in it. Any suggestions?
Ron & DeLana
2018 Force 36FK
2003 Newmar
1998 Pursuit
RonaldH is offline   Reply With Quote
Old 04-20-2019, 08:54 AM   #2
I had that happen once. I used a snake from the inside.
DYNAMAX 2016 FORCE HD
houstonstroker is online now   Reply With Quote
Old 04-20-2019, 08:59 AM   #3
Will try that next. Thanks for the suggestion!
Ron & DeLana
2018 Force 36FK
2003 Newmar
1998 Pursuit
Old 04-20-2019, 11:05 AM   #4
Thanks for snake suggestion, it worked! I know that we will definitely use a lot more water when flushing in the future.
Ron & DeLana
2018 Force 36FK
2003 Newmar
1998 Pursuit
Old 04-20-2019, 11:14 AM   #5
Water is your friend when it comes to the black water tank and flushing the commode.
Old 04-20-2019, 11:17 AM   #6
cavie's Avatar
fill the bowl just like the one at home. Fill the tank with 5 gal. of water after you dump. Do not leave the black gate valve open when on sewer. open and dump then close. You can leave the gray open.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 04-20-2019, 11:33 AM   #7
You can leave the gray open, but it’s nice to follow a dump of the black tank with a dump of the gray to clean the slinky a bit.
2018 F 150 Supercrew 6.5 bed 3.5 EB Max Tow
Jfkmk is online now   Reply With Quote
Old 04-20-2019, 10:18 PM   #8
Yes, we do this already. Thanks!
Ron & DeLana
2018 Force 36FK
2003 Newmar
1998 Pursuit
Old 04-20-2019, 11:02 PM   #9
Question for DX3 and XL owners; is the toilet directly over the black tank? Or is the toilet on the opposite side? Direct drop requires much less water then trying to flush solids and “stuff” over to the other side of the coach then dropping into tank??
Thanks in advance!!
brianh442 is offline   Reply With Quote
Old 04-21-2019, 08:07 PM   #10
GM
bclemens's Avatar
Depends on floor plan. Some have a macerator toilet.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
