Old 12-06-2019, 08:22 PM   #1
Sunlink Starlink model PPJD01-008 12V LED in 2019 Isata 3 24RW pass thru storage is al
There are 2 lights in the rear storage bay, they donít have an on/off switch only a motion sensor. One works fine, but the other is always on unless I hit the battery disconnect switch. Anyone else ever had this problem? The cover pops off and itís easy to access but I donít see how Iíd replace it. The part info is here: https://www.forestriverelectronics.c...ppjd01-008.htm
I donít need the light, wondering if I should just clip the white or black wire. Any recommendations?
ID:	220223   Click image for larger version
ID:	220224   Click image for larger version
acoxFL is offline   Reply With Quote
Old 12-07-2019, 09:05 AM   #2
Keystoner's Avatar
Replace the motion sensor with a switch.
Keystoner is offline   Reply With Quote
Old 12-08-2019, 01:59 PM   #3
They make a model with a switch instead of the sensor, Iíd have preferred that.
led, storage
