Old 05-06-2019, 10:17 AM   #1
MoJoe1003's Avatar
Super tight passenger swivel seat
When rotating our seats to face the living area the passenger seat takes considerable effort to get it to actually turn. I mean considerable. Almost likes it’s stuck. It eventually will move but it takes several tries to get it all the way around. Drivers seat is easy, swivels with minimal effort. Any suggestions on how to loosen up the swivel on the passenger seat?
Joe & Cynthia
2021 Dynaquest XL 3801 TS Cindy 'B'
2021 Jeep Wrangler Unlimited Rubicon Diesel
“Breathe in, Breathe out, Move on”
MoJoe1003 is offline   Reply With Quote
Old 05-06-2019, 10:41 AM   #2
Witch Doctor's Avatar
I don't have your model or know the manufactor of your base plate. But really they are pretty standard bases. I had the same problem on 1 seat, all they did was to use a dry lube on the base and losses a couple of nuts on the base, don't know which ones, but now you can swing it with 1 hand, I think it's to loose but no problem anymore, look at how it rotates and then before loosening anything try dry lube f rist. If that is hard to move then look at the base bolts to the swivel. I do mean I couldn't turn mine at all from the factory.
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-06-2019, 01:36 PM   #3
Commercial Member
Yes, it is always a bit of a crap shoot. Too tight and it is hard to swivel, too loose and it can wobble a bit. Typically if we turn them and they are too tight, we try and loosen some bolts.
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Subscribe for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Sales-Service-Parts https://dynamaxcorp.com/contact-us
Old 05-06-2019, 04:08 PM   #4
I had that problem with the passenger seat. By sittting in the seat and working it a few times it began to turn. It's still tight, but at least I can turn it around now.
2018 DX3 37TS Sunset
2019 Rubicon JLU
2022 RZR Pro 4 Ultimate
rskeans is offline   Reply With Quote
Old 05-07-2019, 01:02 PM   #5
Erinn
Our seat "misbehaves" some times, as well. Putting the seat almost all the way forward, and having the tilt back all the way up (not tilted at all) seems to help.
Ours is a Sunseeker, but I'm fairly certain the chassis (ours is a Ford) are the same?! Our driver's seat is all electric, but the passenger seat rotates & we use it a lot...
Here is the Forest River site url for the Atwood rotating seat: https://s3.amazonaws.com/cd-content....86a86cad7f.pdf
Hope this helps...
Dan and Erinn
2018 Forest River Sunseeker 2420MS
TOAD: Mercedes Smart Car
06/01/18-11/10/18 Camped 43 days!
SunseekerFunseekers is offline   Reply With Quote
Old 05-08-2019, 01:42 PM   #6
I haven’t been able to spin mine around either. You pull yellow handle, the seat will slide over. You still can’t turn it around. Backrest is straight up and seat is all the way to the back.
Popcorn11 is offline   Reply With Quote
Old 05-08-2019, 02:09 PM   #7
Commercial Member
You have to sort of slam it over at a 45 degree angle when you pull the yellow handle. It has to get to the pivot point so it can swivel. (watch your fingers)
Old 05-08-2019, 03:55 PM   #8
I have found the problem. At the front of the seats (on plates) there is a pin. This pin is supposed to ride under the rail, as it gets to the other side of seat support it is supposed to pull down freeing up seat to turn. My pin was working hard forcing the guide to slip off the rail, thus not pulling pin down. I put oil on the pin, seems to have helped. Brackets under the seat probably could stand to be bent towards the guide making it harder to slip off track.
