Originally Posted by BobHanke
Most tank heaters come on below 40 degrees if switch is on.
True, on at 40 degrees. According to the literature on the pass that came on my TT, they don't turn off until near 60 degrees.
This is why they are such battery killers unless you have lots of battery capacity. They run long after they're needed once they kick on.
Best if used only when on shore/generator power or while driving where some or all of the draw is offset by power from alternator.
Once tanks are warmed up one can stop for lunch or rest breaks and tanks wont freeze as it takes a while to cool off.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
