Old 03-15-2019, 07:41 PM   #1
Tekonsha P3 brake controller red wire.
2018 Isata 3. I tried wiring in the above brake controller. I found the blue wire under the seat and ran it forward. The black power wire goes to battery and the white goes to negative.
For the red wire out of the controller, I was not able to find the cold side of the brake light switch. There are 4 pink wires on the MB brake light switch, wide black is hot, then there is thin black, thin blue and thin green. None of those would go hot when I depressed the brake pedal while engine is running.
What am I missing? Where are folks tapping in the red wire off their controllers?
UPDATE: etrailer.com comes through again. It is the pink wire with the thin green stripe. Not enough voltage to light up an incandescent test light. That’s why I couldn’t see it.
Thanks.
Tgrossman is offline   Reply With Quote
Old 05-01-2019, 12:10 PM   #2
Ragtimeplayer's Avatar
Do you have an MBS platform? I can’t find a Tekonsha wiring harness for the Mercedes.
2017 Forester MBS 2401R
2011 F350 PSD w Torklifts/Bags and H&S DPF delete
Ragtimeplayer is offline   Reply With Quote
Old 05-01-2019, 12:42 PM   #3
Commercial Member
Yes, they went CANbus on everything. Makes things really difficult when we want "trigger wires".
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Subscribe for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Sales-Service-Parts https://dynamaxcorp.com/contact-us
Old 05-01-2019, 01:28 PM   #4
Iwannacamp's Avatar
Maybe an idea... IF you cannot do ANYTHING else. They make stop light switches that are hydraulically activated.. think 50s and 60s cars etc.. I am sure you could find a connection point somewhere without cutting anything.
2017 Puma 297RLSS
Old 05-01-2019, 01:41 PM   #5
Iwannacamp's Avatar
Ideas?
https://www.etrailer.com/question-238891.html
https://www.etrailer.com/question-239741.html
Read this thread.. especially #17 and on
Brake Controller 2017 Sprinter Chassis - iRV2 Forums
2017 Puma 297RLSS
Old 05-01-2019, 01:51 PM   #6
Commercial Member
I think, if you read his "edit" he has it figured out and all is good.
Old 09-14-2019, 06:00 PM   #7
I am going down the same road with my 2020 Isata 3 and have decided to order the same controller. Before ordering, I need to know if the trailer connector is MB factory pre-wired or was this done by someone else? I have not looked for the telltale green connector under the seat yet. Has anything changed since Tgrossman installed his controller? Any and all help deeply appreciated.
Battchief
Battchief is offline   Reply With Quote
brake control, controller
