On the DX3, I located the harness on top of the driver side fuel tank and ran into the interior of the cab.
It had the following wires.
BLUE
RED
WHITE
ORANGE
My new Tekonsha P3 had the generic wiring harness with the following wires.
WHITE - To actual ground of battery.
BLACK - Through 30a circuit breaker to battery positive.
RED - To cold side of brake switch.
Blue - To trailer brake.
Am I to assume correctly that the factory wire harness completes the above requirements as the factory WHITE is routed to the actual ground side of the chassis battery and not a chassis ground screw per the Tekonsha instructions, the factory RED runs to the cold side of the brake switch, the factory BLUE runs to the trailer brake plug for the trailer brakes, and the factory ORANGE is the positive routed through a 20a or 30a auto-reset circuit breaker?
Thanks in advance.
