05-20-2018, 05:55 PM
#21
Truck System Technologies Rep
Tst tpms
Sounds good Casey! I'm always here if you need me!
Thanks,
Mike Benson
TST TPMS
210-420-0132
Originally Posted by caseymyers
Ahaa. So it will always read #1 as I will only have one trailer, my TOAD. Got it. So actually I've programmed the first two sensors correctly and didn't know it. For me I can ignore the number 1 in the display. Thanks. Now I'll move on to the other steps, setting pressure and such. Thanks Mike.
05-21-2018, 04:25 AM
#22
Install
Anyone install the TST on the I5? Any issues with getting them on the inside wheel?
2017 Isata5 36DS
05-21-2018, 09:03 AM
#23
There was another thread on here awhile back by sseaner not sure how others have done it. You might ask Mike from TST he's on this thread.
Old Navy Chief
2019 Isata 5 36' DS 4x4
2015 Jeep Rubicon Toad
Days camped 2021 = 25
05-21-2018, 09:43 AM
#24
Here is the link;
http://www.forestriverforums.com/for...ew-154246.html
Scott & Heather
2018 Isata 5 DS
05-21-2018, 10:59 AM
#25
Crossfire
Nice job on the Crossfire setup! I see your pressure monitors caps are on the outside. I'm wondering is there enough finger room to screw TST flow thru on the inside wheel? Tight spot just to get an air gauge in.
2017 Isata5 36DS
05-21-2018, 11:08 AM
#26
Look closely at the finished photo. No need for Flow Thru. You can fill both tires at the same time at the fill valve below the gauge.
Old Navy Chief
05-21-2018, 11:15 AM
#27
Denver To Yuma In 90 Days
I have a TireMinder system...
I could include the truck, but it has it's own built-in TPMS.
The only issue I have with mine is that I need a tiny little allen wrench to take each off to add air to the tires, but it's not all that bad...just kind of a PITA.
Love it, though!
05-21-2018, 11:18 AM
#28
[QUOTE=KRedburn;1810681]I use EEZTIRE works great[/QUOTE
I also use the Eeztire system. Love it! I just posted a recent experience I had on the "Goshen Rally" thread.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
05-21-2018, 11:19 AM
#29
My bad, Guess I should have said I wasn't installing the Crossfire.....
2017 Isata5 36DS
#30
Love it, though!
I think one of the reasons folks like the TST system is no allen wrench. Comes with a larger tool you use to screw it on. I have no experience I just bought mine and have not yet installed it.
Old Navy Chief
05-21-2018, 11:40 AM
#31
Ibought mine from a friend who upgraded to a more expensive setup...
Price was right so I jumped on it!
First time I used it I got a low tire warning and found a nail in the tire.
05-21-2018, 01:42 PM
#32
No room or way to install the sensor on the inside tire. You could go with valve extension for the inside tire but I opted for one easy fill point and balanced pressure. The flow through sensors have to be mounted on a metal valve stem and are not recommended to be mounted on an extension.
Scott & Heather
2018 Isata 5 DS
05-21-2018, 02:10 PM
#33
I had my doubts they'd fit in there.Thanks for verifying that.
2017 Isata5 36DS
