02-22-2016, 01:34 PM
Tire Pressure
Haven't been to scales yet but will. I see freightliner shows 110psi front and rear.. forest river shows 110psj on their sticker located in the door jam. Is everyone running max 110psi in all their tires?
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
02-22-2016, 08:19 PM
I run 110-120 depending. I try to keep everything at 110
2016 Dynamax Force. Just-Rite2
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
02-22-2016, 08:29 PM
110 is max pressure on the Michelin 275 80R 22.5 unless your tires are different 120 psi is over inflated.
02-22-2016, 08:30 PM
At cold pressure that is..
02-22-2016, 09:24 PM
I think it is simply a math exercise. The tires are rated xxxLBS at xxxPSI. Once you know the weight you can ratio the PSI.
02-22-2016, 09:28 PM
Michelin and Goodyear both have tire inflation tables once you know 4 corner weights.
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
02-22-2016, 10:16 PM
Agree on the psi table chart by tire manufacturer, not new to that. Was just curious as to what folks typically run as a ballpark. Once I get to scale.. the mystery will be over and "I'll" post my findings.. I do like to fire up conversation on topics. Keeps Dynamax forum active.. :-)
05-06-2016, 03:53 PM
Slim - did you ever get to the scales?
Mike
2016 Force HD 36
05-06-2016, 04:00 PM
Yes I did. Everything loaded the way "we" like to travel. No tow vehicle attached. Of course thats not adding much if it were since wheels are n the ground.
05-07-2016, 11:32 AM
Commercial Member
Michelin has a site on tire pressures. 110psi is based on max loading. Looks like slim is just over 6,000 lbs short of max load. Unless it is driving harshly, 110 would be fine...but for softer ride, run them lower.
05-07-2016, 01:11 PM
Thanks for weight response Slim. Good to know. I am hovering around 27k as well. 110PSI (cold) works good for me. I tried less PSI, but it does not handle as well when it is below 110PSI - for me.
Mike
2016 Force HD 36
05-07-2016, 08:07 PM
I'm running 110 psi front 105 psi on the drive axle. Good ride.
