Old 02-22-2016, 12:34 PM   #1
AWF1945's Avatar
Tire Pressure
Haven't been to scales yet but will. I see freightliner shows 110psi front and rear.. forest river shows 110psj on their sticker located in the door jam. Is everyone running max 110psi in all their tires?
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
AWF1945 is offline   Reply With Quote
Old 02-22-2016, 07:19 PM   #2
halla's Avatar
I run 110-120 depending. I try to keep everything at 110
2016 Dynamax Force. Just-Rite2
2018 Dynamax Force HD BH---Just Rite-2
halla is offline   Reply With Quote
Old 02-22-2016, 07:29 PM   #3
AWF1945's Avatar
110 is max pressure on the Michelin 275 80R 22.5 unless your tires are different 120 psi is over inflated.
Old 02-22-2016, 07:30 PM   #4
AWF1945's Avatar
At cold pressure that is..
Old 02-22-2016, 08:24 PM   #5
I think it is simply a math exercise. The tires are rated xxxLBS at xxxPSI. Once you know the weight you can ratio the PSI.
dmax36 is offline   Reply With Quote
Old 02-22-2016, 08:28 PM   #6
edgewant's Avatar
Michelin and Goodyear both have tire inflation tables once you know 4 corner weights.
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 02-22-2016, 09:16 PM   #7
AWF1945's Avatar
Agree on the psi table chart by tire manufacturer, not new to that. Was just curious as to what folks typically run as a ballpark. Once I get to scale.. the mystery will be over and "I'll" post my findings.. I do like to fire up conversation on topics. Keeps Dynamax forum active.. :-)
Old 05-06-2016, 03:53 PM   #8
Slim - did you ever get to the scales?
Mike
2016 Force HD 36
BLK-9 is offline   Reply With Quote
Old 05-06-2016, 04:00 PM   #9
AWF1945's Avatar
Yes I did. Everything loaded the way "we" like to travel. No tow vehicle attached. Of course thats not adding much if it were since wheels are n the ground.
Old 05-07-2016, 11:32 AM   #10
GM
bclemens's Avatar
Michelin has a site on tire pressures. 110psi is based on max loading. Looks like slim is just over 6,000 lbs short of max load. Unless it is driving harshly, 110 would be fine...but for softer ride, run them lower.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
pressure, tire
