Old 10-03-2019, 12:35 PM   #1
PRK
Tire pressure
My tires have 80 psi max inflation rating. Forest a River lists 61 psi on the door jam. Is this 61 psi rating for a CCC that is maxed out? I’m thinking I should be at the higher psi due to the load?
N.E. MN
2020 Isata 3 24 FW
PRK is offline   Reply With Quote
Old 10-03-2019, 03:26 PM   #2
Whalenss's Avatar
The best way to determine correct tire pressure is to weight the unit fully packed, including fuel, then refer to the tire manufacturer's recommendation on weight and tire pressure.
For my unit recommended tire pressure from FR included factoring in CCC. I know this because I have weighted the coach fully packed and refered to tire manufacturer recommendation.
Pat
2017 Isata 5
Whalenss is offline   Reply With Quote
Old 10-03-2019, 04:04 PM   #3
X2
cfo111 is offline   Reply With Quote
Old 10-03-2019, 04:09 PM   #4
Bill Davis's Avatar
When I replaced mine with Michelin’s I used their tire pressure chart against my Cat Scale axle weight and my optimum pressure was 55psi.
2008 Dynaquest 340xl
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
Previous coach 2017 Isata 3RW
Also,3 Diesel pushers, 1Bvan, 2 class Cs
Bill Davis is offline   Reply With Quote
Old 10-03-2019, 04:19 PM   #5
Retired Old Fart
dward51's Avatar
Tire pressure on the sticker (trailer or your tow vehicle) relates to the capacity of the trailer/vehicle as it left the factory.
If you have changed tires, use the sidewall PSI number to get the maximum carrying capacity. If you run an 80psi tire at 61psi, that tire will not have the full rated capacity that is on the side wall as that capacity is at the full PSI. Same is true for your tow vehicle. Most tire companies have a chart to show the load range capacity de-rating for a lower PSI.
Here is an example from Goodyear.
https://www.goodyearrvtires.com/pdfs/rv_inflation.pdf
Edit ------
I totally missed you have a Isata 5, but the sticker vs tire PSI value info remains the same.
Just the 2 of us in a...
"Currently between trailers"
Sold the 246RKS in 2023
dward51 is offline   Reply With Quote
Old 10-03-2019, 04:21 PM   #6
TowPro's Avatar
Sounds like you have the mbs chassis like we do. I run 61 psi
TowPro is offline   Reply With Quote
Old 10-03-2019, 05:10 PM   #7
PRK
Thanks for your replies. I’ll run at 80psi until I get to the scales then adjust from there.
N.E. MN
2020 Isata 3 24 FW
Old 10-03-2019, 05:37 PM   #8
milkman55's Avatar
I think running them at the max PSI may cause issues due to over inflation. I never could find a load chart from Continental for the OEM tires, but I run mine fully loaded to gross weight and have used 63 PSI the past two years and 16,000 miles. The wear on the tires is even and the ride is acceptable.
2021 Isata 5 30FW
2022 Ford Ranger Tremor 4x4
(Previously owned a 2017 Isata 3 24FW)
milkman55 is offline   Reply With Quote
Old 10-03-2019, 05:42 PM   #9
PRK
Thanks. I have been unsuccessful trying to find the Continental load chart as well.
N.E. MN
2020 Isata 3 24 FW
Old 10-03-2019, 06:18 PM   #10
Whalenss's Avatar
Try this link.
https://www.continental-truck.com/tr...downloadcenter
Pat
2017 Isata 5
Old 10-03-2019, 06:49 PM   #11
milkman55's Avatar
I have seen that link before and it only lists one 16” tire size and it’s not the tire used on the Sprinter, close, but not exact. Based on that chart, 65 PSI looks about right.
2021 Isata 5 30FW
Old 10-03-2019, 08:12 PM   #12
chroniekon's Avatar
I run mine at 65.
2017 Isata 3 24FW
2004 Jeep Wrangler
chroniekon is offline   Reply With Quote
Old 10-03-2019, 10:06 PM   #13
Barch's Avatar
I run 64 psi.
2019 ISATA 3 FW
LiFePO4 Upgrade
2013 Honda CRV Toad
Barch is offline   Reply With Quote
Old 10-03-2019, 11:53 PM   #14
Dbrote's Avatar
I run 65 front and 70 rear. I also seem to be running about 250 lbs over on my MBS 2400R
Dbrote is offline   Reply With Quote
pressure, tire
