10-16-2018, 09:37 PM
Location: Bellingham, Wa: Boise, Id;Rancho Cucamonga, Ca
tire pressure monitoring system
Brian, i enjoyed meeting you, but can't remember the name of one of the tpms systems you were studying. can you send info?
thank you,
i am even more interested since i learned that the tires cost nearly $400 each to replace which i will have to do, at least with the fronts after only 20,000 miles.
on the other hand, one way to understand the quality pursuit of a manufacturer is to look at the quality of the components. i'm guessing Dynamax could spec less expensive tires. unfortunately, our tires left the factory/dealership were significantly under-inflated.
17,000 + miles and still loving it
10-16-2018, 10:46 PM
I use this system. EEZ tire
Have had no issues once set up.
Note setup is easy.
Ken and Kathy Redburn
2018 DX3 37TS (The Taj)
10-17-2018, 10:31 AM
Commercial Member
We're looking at TST. They were just bought by Pressure Systems International
10-17-2018, 10:57 AM
Back in April of 2017 so a year and half ago correct ?
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30X
10-17-2018, 11:02 AM
Commercial Member
Not sure when it happened, just know the guys from PSI were here and said they bought TST.
10-17-2018, 11:44 AM
Commercial Member
What ever brand TPMS you get you need to be sure your settings will give good, advanced warnings. I have a couple of blog posts on how I suggest TPMS be set.
Note I write for RVTravel.com and they have advertisements on the blog I write for them. I bought Tire Traker as I like their warranty but I do not sell TPMS.
I also did a multi-month test of two different systems and have posted the data on other blog posts if you are interested in the results.
.Write a blog on RV tire application RV Tire Safety. 48 years experience as tire design & forensic engineer. My RV Freelander 23QB on Chevy 4500 chassis. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Mar 20-22 Tucson AZ
10-17-2018, 11:48 AM
Cool. I've been using the TPMS system from RVibrake just so I wouldn't have to deal with multiple screens, but I've had lots of problems with them. Their service and support has been exceptional...they've replaced a subset of the sensors a couple of times, and they've replaced all 6 sensors on a separate occasion. After getting 6 brand new ones a few of weeks ago, three are already non-responsive. I just ordered the TST system to replace it...seems like this crowd deems it the best.
2018 DX3 37BH
10-17-2018, 12:32 PM
TST user here
Yes, PSI bought TST about a year ago. They have made some great improvements with the company. We have been using TST for about 3 years, and they have by far the best TPMS in my opinion. We've tried Tire Traker and Tire Minder, and they just don't have the features or quality that TST has.
10-17-2018, 12:40 PM
TST user for last 8 years. Two prior travel trailers and now on my ISATA 3. System works flawlessly. I've changed the batteries, added additional sensors and reprogrammed the unit. No problems. Highly recommended.
2019 ISATA 3 FW
LiFePO4 Upgrade
2013 Honda CRV Toad
10-17-2018, 12:57 PM
I have the latest TST with color monitor. LOVE IT. Use if for my Suburban and 2018 ROO 233S. I did switch our all of the tires rubber valve stems to metal stems prior to installing the TST system. Works great, simple to install and use, reliable so far. No issues.
2018 Rockwood Roo 233S
2003 Chevy 3/4T Suburban
TST Tire Monitor Tow/Trailer
10-17-2018, 02:30 PM
Old Engineer
TST User
I have a TST system on my rig and am very happy with it.
No problems, easy to set-up.
2019 Dynamax Isata 3 24RW
Smart Car Towed 4 Down
Quote: "When all else fails, read the manual!"
10-17-2018, 02:40 PM
I was a TST user until recently. My flow throughs got stuck on my Dodge valves. Corrosion.
My advice if getting TST is to avoid the flow through version.
I have to replace two Dodge TPMS sensor valves at $91 each plus labor.
I asked TST for suggestions to remove their sensors and was told tomorrow. That was months ago.
Tire Minder may be my next set as they offer sensors with your choice of metal.
2017 Dynamax REV 24RB
2018 Ford F-150
10-17-2018, 03:25 PM
Just returned from a 7k + miles adventure using a new TST-507 on my Motorhome. Worked flawlessly and gave me peace of mind while driving. Comes with a easy to read color monitor. Highly recommend this product.
Fred
10-17-2018, 06:04 PM
Thought I'd jump in here. I did a round trip Florida to Maine and back and 3 of the 4 RVI sensors failed on the trip. I have to say they were awesome in admitting that they were having mfg issues and have sent a full set of sensors to replace all of mine. I like the system as it provides both pressure and temp for the tires. Great customer support. We'll see how the new units work. Florida to KC in the next couple weeks.
Jerry Austin
2018 Dynamax Isata 4 25 FW
2011 Rubicon
2018 Dynamax REV 24 TB Sold 2/2021
10-18-2018, 07:27 AM
After about the third or fourth troubleshooting iteration, RVI admitted the same to me and sent a full replacement set. Half of them failed within a month, but they told me that of the 5000+ in the new batch, there had only been 7 failures. I hope you have better luck. I like the product and having only a single screen on the dash for the toad brake and TPMS makes a ton of sense. I’m tired of worrying about them, though, so I’m giving TST a shot.
2018 DX3 37BH
10-18-2018, 07:50 AM
Georgia Rally Coordinator
We just had the TST folks at the Bamaganza rally and they have made great improvements to there products. They are very helpful. You ever thought about follow up phone call they are always available and have always had solutions to the problems you have. If I recall they have made improvements to the flow through system. I have had there system now for almost 2 years and no issues. They also replaced my color monitor free as there was an issue with the first batch. You wont find a better company to deal with. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
10-18-2018, 08:04 AM
I’ve been very happy with the TST on my DX3. Didn’t have to do anything special to install. Was even happier when I realized I could remove the anti theft thingies for the rear duallies. Makes it much easier to take on/off.
2016 Dynamax DX3 - Big Blue
10-18-2018, 04:00 PM
I have the RVI system. Had a few failures but they have replaced them all quickly. Just did a 2000 mile trip with no issues. I did remove them for winter to help preserve battery life, as they did recommend.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
10-18-2018, 07:53 PM
Retired Army Paratrooper
TST has an excellent system, very easy to set up. I really like that you get your tire pressure as soon as you turn the system on, don't have to wait for tires to warm up. I bought mine at www.technorv.com
Dennis & Zoleta
Retired US Army
2010 Grand Sport GT
10-18-2018, 09:45 PM
I purchased Tire Minder and used it for a year. Not real happy with it so I upgraded to TST. Great product.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
