Old 03-18-2018, 06:53 PM   #1
dlfishing's Avatar
Tire pressure settings
In another forum topic someone replied to my comment about using 80psi in my DX3 by saying I should fill them to the max rated...on my Michelin tires I think the max is 110 psi.
I have always utilized the tire manufacturers charts to pressure up my RV tires.
At a FMCA rally both Cummins rep and Freightliner rep said the same thing that I have always done. Attached is a copy of a page from the handout that was provided by Freightliner
dlfishing is offline   Reply With Quote
Old 03-18-2018, 06:57 PM   #2
halla's Avatar
do you use 80psi all around or just on the front?
2018 Dynamax Force HD BH---Just Rite-2
halla is offline   Reply With Quote
Old 03-18-2018, 07:03 PM   #3
dlfishing's Avatar
Since my weight distribution seems to be nearly the same on all tires, I had it weighed on a truck scale, I use the same on all tires.
I only know the total weight on each axel, I would like to one day to weigh the tires individually to see if the left and right are the same.
I had my RV fully fueled and loaded for a trip when I weighed it.
Old 03-18-2018, 07:08 PM   #4
halla's Avatar
cool, probably rides better at 80 than 110
Old 03-18-2018, 07:23 PM   #5
dlfishing's Avatar
Yes, it does ride better.
I had my RV serviced at a truck repair shop and they were ‘NICE’ enough to fill all my tires to 110psi. Drove my tire monitor crazy until
I corrected the pressures. So I was able to feel the difference.
Old 03-18-2018, 08:04 PM   #6
Webefine's Avatar
This has come up before, I agree with Dl 100%. You should have your rig weighed when fully loaded and set the air in your tires according to the manufacturer guide. Not only will it ride better but you should get better tire life, even though RVers with rigs like ours rarely wear tires out they just get old.
This isn't just a truck thing. Most car tires have a higher max pressure rating than what the door sticker says, this is because the manufacturer of that vehicle has determined that the pressure on the door sticker is what the tires need for the max weight of the car.
Webefine is offline   Reply With Quote
Old 03-19-2018, 11:14 AM   #7
RV Randy's Avatar
Attachment 165581
I agree, I would never just fill a tire to the maximum pressure. But in addition to loaded axle weight, you also need to consider impacts to handling. If you are loaded lightly and like the softer ride at 80 psi, that's OK. But the softer setting could also increase sidewall roll and leaning when cornering or when encountering stiff cross winds. With a leaf sprung front axle this can cause chassis steering. If you aren't happy with the lean and steering wheel movement you get in cross winds, trying bumping up your psi 5 psi at a time (all tires) to see if you get an improvement so you can find a happy median.
Randy & Dee
2018 DX3 37TS
"Orange Crush"
RV Randy is offline   Reply With Quote
Old 03-19-2018, 11:39 AM   #8
dlfishing's Avatar
Wouldn’t you think the tire manufacturer takes all that in consideration!
Old 03-19-2018, 12:46 PM   #9
Bill Davis's Avatar
If you read what's on the tire it says what the maximum pressure is allowed on a cold tire. It doesn't know what vehicle it is installed on. Always use the manufacturers recommend pressure, never the max.
Bill Davis is offline   Reply With Quote
Old 03-19-2018, 01:06 PM   #10
hook47's Avatar
When contemplating a diesel pusher I was interested in the tire pressure issue from that segment of the RV'ing world. Not positive, too lazy to try and find it again, but I think Lazy Days had an interesting tutorial on this subject. IIRC if you couldn't weigh each tire individually, weigh the axle and divide by number of tires. Check the tire manufacturer's site for proper psi and add 5 psi to compensate for unequal loading.
Like I said, If I Remember Correctly..
hook47 is offline   Reply With Quote
pressure, tire
