Old 10-31-2018, 04:11 PM   #1
AWF1945's Avatar
Tire wear question.
Anyone getting unusual tire wear as shown rear duals. Same air pressure. Same on both sides. Outer edges seem to be wearing.
ThanksClick image for larger version
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
AWF1945 is offline   Reply With Quote
Old 10-31-2018, 04:40 PM   #2
AWF1945's Avatar
ThanksAttachment 190454
Could be just turning causing it.. scrub.
Old 10-31-2018, 05:02 PM   #3
Perhaps post a picture that shows the entire tread of the tires.
2017 Riverstone 38FB Legacy
2018 F450
LegacyFB38 is offline   Reply With Quote
Old 10-31-2018, 05:16 PM   #4
AWF1945's Avatar
Here ya go Click image for larger version
Old 10-31-2018, 10:51 PM   #5
My guess is the pressure is a bit low, especially on the inside tire.
BTW, you have aluminum wheels on the inside rear. Did you do that are is it factory?
2018 F450
Old 11-01-2018, 07:50 AM   #6
GM
bclemens's Avatar
M2 comes with aluminum inner and outer.
I believe they say they are "truer" wheels and provide better cooling when braking.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 11-01-2018, 11:50 PM   #7
caseymyers's Avatar
It is wearing as if the inside tire is slightly lower in pressure than the outside tire.
Old Navy Chief
2019 Isata 5 DS 4x4
2015 Jeep Rubicon Toad
Days camped in I5 2019 = 26
caseymyers is offline   Reply With Quote
Old 11-02-2018, 01:35 PM   #8
AWF1945's Avatar
Seems as if, but, they're the same pressure.
Old 11-02-2018, 01:44 PM   #9
chroniekon's Avatar
Is the same thing happening on the set of duals on the other side?
2017 Isata 3 24FW
2004 Jeep Wrangler
chroniekon is offline   Reply With Quote
Old 11-02-2018, 02:07 PM   #10
Running the same pressure on inner and outer may not be ideal. I've heard arguments that one (or the other!) should be a higher pressure. There doesn't seem to be much good information on the subject.
I have 5000 miles on my F450 dually, and have been running the same pressure inside and outside. So far, so good. If my tires showed your wear pattern, I'd consider bumping up the inside tire pressure a bit...especially if both sides show similar wear patterns.
Hopefully some more experienced than I will chime in.
2018 F450
tire
