Originally Posted by caseymyers
Depending on the Shackle Kit you buy, this plate will work with just about any tow bar. I've used both Blue Ox and Roadmaster, I have two separate shackle kits.
I use the same Currie tow bar plate on my 2015 Wrangler with a Demco tow bar, Demco sells adapters for this plate. It is an easy install and provides a solid front skid plate as well. I think it is a perfect solution for the 2007 and newer Wrangler.
