Old 06-13-2018, 11:52 AM   #1
FOURWHL's Avatar
TPMS in Alcoa wheels
Alright M2 users, whoís got TPMS installed and what did you do to get the sensors to fit? Any pics appreciated and would love to know what brand.
Every time I look at them I get all ready to roll then as soon as I realize Iíll likley need to mess around with extenders and such I end up losing steam and deciding not to mess with / over complicate a system thatís working. I think itís time I bite the bullet and stop tempting fate as Iím religious about checking pressure before leaving on a trip but definitely not great about doing it in progress or upon departure.
Looking at TST or Eeztire but open to suggestions. Really whichever involves the least amount of new failure points intoduced will be best.
2016 Dynamax DX3 - Big Blue
FOURWHL is offline   Reply With Quote
Old 06-13-2018, 07:46 PM   #2
RV Randy's Avatar
I put the Crossfire stuff on the rear duals. Makes it easy at a glance to know if your pressure is correct or dropped. Plus, the right crossfire unit has the extra valve spots so you can still put separate TPMS sensors on each wheel. And, there is a 3rd valve stem that is easy to reach and allows you to air up both tires simultaneously w/o removing the sensors. The cross fire takes about 20 minutes to install on each side and you don't need to bother with leaky stem extensions, etc.
The fronts obviously are an easy screw-on. You can get the air though sensors so you dont need to remove them to add air.
I use the TST brand because they include a nice color monitor.
Randy & Dee
2018 DX3 37TS
"Orange Crush"
RV Randy is offline   Reply With Quote
Old 06-13-2018, 07:59 PM   #3
FOURWHL's Avatar
I was considering that avenue as well. Thanks Randy
Old 06-14-2018, 12:45 PM   #4
Using the ones from rvibrake since I already had their tablet.
I had trouble with the sensors on the rear inner tires which I believe were caused by the valve stem extensions. I ended up removing them altogether. It's a bit of a pain to install/tighten the inner sensors now, but they work great.
2018 DX3 37BH
mookieblaylock is offline   Reply With Quote
Old 06-14-2018, 01:32 PM   #5
FOURWHL's Avatar
So you’ve got the sensors directly on both of the rear valve stems? Understand the PITA it will cause filling but that’s still encouraging.
Old 06-14-2018, 01:36 PM   #6
Yes...sensors directly on all rear valve stems. Both extensions have been removed. Both caused issues with the sensors, and the one on the passenger side was leaking (I previously had to tighten both of them).
2018 DX3 37BH
Old 06-14-2018, 01:52 PM   #7
FOURWHL's Avatar
Heh yeah that’s exactly what I’m trying to avoid. More maintenance/inspection items when I’m trying to reduce things that can go wrong lol
Old 06-14-2018, 04:00 PM   #8
Ender's Avatar
I have the TST system, it works fine with no mods. I just put a sensor on each valve stem, I didn't remove extensions. No muss, no fuss.
2018 Dynamax Force HD 37BH
AKA "Thunderwagon"
Ender is offline   Reply With Quote
Old 06-14-2018, 04:04 PM   #9
FOURWHL's Avatar
Good to hear! How is it taking the outer duallies on/off for filling?
Old 06-14-2018, 04:16 PM   #10
Ender's Avatar
It's a little tricky but not a big deal. I don't do it very often - I just set the pressures cold and run it. Based on what I'm seeing on the monitor, they hold pressure great.
AKA "Thunderwagon"
tpms, wheel
