Great thing about the color monitor, is the antenna is built in, the charging port is Micro USB to USB or 12 Volt. It will monitor up to 38 tires plus 4 different trailers. It is capable of monitoring up to 110 tires. it will alert on Low PSI, High PSI, Fast Leak, and High Temp. Rather than an icon that appears at the bottom of the old 507 the new monitor will read out High Pressure, Low Pressure, Fast Leak, and High Temp so the user can visually see the alert. It will also give an audible alert(Beep-Beep-Beep), as well as a red flashing light.
If anyone wants any of the systems from the 510, 507 standard monitor and the 507 color monitor PM me.
Team Watts
2017 DiXie3 Blue
37RB
Chuck, Army (Ret) & Patricia, Barber
